2.8 tft capacitive touch display
JJAAWW
Post by JJAAWW »
I've come across a program to display bmp to the display. I'm not able to get it to work
I've displayed the code below
#include <SD.h>
#include "TFTv2.h"
#define MAX_BMP         25      // Maximum number of BMP files
#define FILENAME_LEN    16      // Maximum file name length
#define SKETCH "TFT_Mod1 / Rev2"
// Determine how a file will be displayed, sweeping the screen vertically:
#define DOWN 0           // display from top to bottom
#define UP   1           // display from bottom to top
#define IN   2           // display from top/bottom in to center
#define OUT  3           // display from center out to top/bottom
const int PIN_SD_CS = 4;           // pin of sd card
// Display pixel size, as defined in TFTv2.h
uint32_t DspHeight = MAX_Y + 1;
uint32_t DspWidth  = MAX_X + 1;
float    DspAr = (float)DspHeight / (float)DspWidth; // Aspect Ratio
// Specify the BMP file read buffer
#define BUFFPIXEL 400
uint8_t  SdBuffer[BUFFPIXEL * 3];  // Allow for color depth of 3 bytes/pixel
uint16_t PixelColor[MAX_X + 1];
// BMP File specifcations
uint16_t NumBmpFiles = 0;              // Number of BMP files
char BmpFiles[MAX_BMP][FILENAME_LEN];  // List of image files
char* fileName;                        // Current file on display
uint32_t fileSize;
uint32_t BmpImageOffset  = 0;          // Offset of image in the BMP file
uint32_t BmpHeight;                    // BMP image pixel height
uint32_t BmpWidth;                     // BMP image pixel width
uint8_t  BmpDepth;
File BmpFile;
// search root to find bmp file
void searchDirectory() {
    File root = SD.open("/");                       // root
    while (NumBmpFiles < MAX_BMP) {
        File entry =  root.openNextFile();
        if (!entry) {
            break;
        if (!entry.isDirectory()) {
            String name = entry.name();
            int len = name.length();
            if (len >= 5 && len <= 12) {
                strcpy(BmpFiles[NumBmpFiles], name.c_str());
                name.toUpperCase();
                if (name.endsWith(".BMP")) {
                    NumBmpFiles++;
        entry.close();
    Serial.print("get ");
    Serial.print(NumBmpFiles);
    Serial.println(" files: ");
    for (int i = 0; i < NumBmpFiles; i++) {
        Serial.println(BmpFiles[i]);
    Serial.println();
    Serial.begin(115200);
    Serial.println(F(SKETCH));
    pinMode(PIN_SD_CS, OUTPUT);
    Tft.TFTinit();
    Sd2Card card;
    card.init(SPI_FULL_SPEED, PIN_SD_CS);
    if (!SD.begin(PIN_SD_CS)) {
        Serial.println("SD failed!");
        while (1);                              // init fail, die here
    Serial.println("SD OK!");
    searchDirectory();
    TFT_BL_ON;
    static int dirCtrl = UP;
    for (unsigned char i = 0; i < NumBmpFiles; i++) {
        fileName = BmpFiles[i];
        BmpFile = SD.open(fileName);
        if (!BmpFile) {
            Serial.print("didnt find image: ");
            Serial.println(fileName);
            break;
        if (!bmpReadHeader(BmpFile)) {
            Serial.println("bad bmp");
            break;
        bmpdraw(BmpFile, dirCtrl);
        BmpFile.close();
        dirCtrl = (dirCtrl + 1) % 4;
// This procedure reads a bitmap and draws it to the screen
// its sped up by reading many pixels worth of data at a time
// instead of just one pixel at a time. Increasing the buffer takes
// more RAM but makes the drawing a little faster. 20 pixels' worth
// is probably a good place
// dir - DOWN: sweep top to bottom
// dir - UP:   sweep bottom to top
// dir - IN:   sweep from edge to center
// dir - OUT:  sweep from center to edge
void bmpdraw(File f, int my_dir) {
        Display the BMP file.
        If the image is narrower than the screen (BmpWidth < DspWidth),
        then center the display on the width.
        If the image is shorter than the display (BmpHeight < DspHeight),
        then center the image on the display height.
        If the image is wider than the screen (BmpWidth > DspWidth),
        then crop the image width from both sides.
        If the image is taller than the display (BmpHeight > DspHeight),
        then crop the image width from both top and bottom
    int dir = my_dir == IN || my_dir == OUT ? UP : my_dir;
    // Compute scanline padding
    uint8_t padding = 0;
    uint16_t scanlinebytes = BmpWidth * BmpDepth;
    while ((scanlinebytes + padding) % 4 != 0) {
        padding++;
    uint32_t time = millis();    // Milliseconds taken to display the image
    uint16_t offset_x = 0,       // Display Width Margin
             offset_y = 0;       // Display Height Margin
    float    skip = 1.0;         // Image Shrink Factor
    float    BmpAr = (float)BmpHeight / (float)BmpWidth; // Image Aspect Ratio
    bool     done_y = false;
    // First check to see if the image needs to shrink to fit onto the display:
    if (BmpWidth > DspWidth || BmpHeight > DspHeight) {
        if (BmpAr >= DspAr) {
            skip = (float)BmpHeight / (float)DspHeight;
            offset_x = (uint32_t)((float)DspWidth - (float)DspHeight / BmpAr) / 2;
        } else {
            skip = (float)BmpWidth / (float)DspWidth;
            offset_y = (uint32_t)((float)DspHeight - (float)DspWidth * BmpAr) / 2;
    } else {
        if (BmpWidth < DspWidth) {
            offset_x = (DspWidth - BmpWidth) / 2;
        if (BmpHeight < DspHeight) {
            offset_y = (DspHeight - BmpHeight) / 2;
    #if(1)
    Serial.print(F("\nFile: "));
    Serial.print(F("Size: "));
    Serial.println(fileSize);
    Serial.print(F("dir = "));
    switch (my_dir) {
        case UP:   {
                Serial.println(F("UP"));
                break;
        case DOWN: {
                Serial.println(F("DOWN"));
                break;
        case IN:   {
                Serial.println(F("IN"));
                break;
        case OUT:  {
                Serial.println(F("OUT"));
                break;
    #endif
    #if(1)
    Serial.print(F("padding: "));
    Serial.println(padding);
    Serial.print(F("DspWidth, DspHeight = "));
    Serial.print(DspWidth);
    Serial.print(F(", "));
    Serial.println(DspHeight);
    Serial.print(F("BmpDepth = "));
    Serial.println(BmpDepth);
    Serial.print(F("BmpWidth, BmpHeight = "));
    Serial.print(BmpWidth);
    Serial.println(BmpHeight);
    Serial.print(F("BmpAr, DspAr = "));
    Serial.print(BmpAr);
    Serial.println(DspAr);
    Serial.print(F("skip = "));
    Serial.println(skip);
    Serial.print(F("offset_x, offset_y = "));
    Serial.print(offset_x);
    Serial.println(offset_y);
    #endif
    uint16_t ydn = DspHeight - 1,
             yup = 0;
    float    fx = 0.0,
             fyup = 0.0,
             fydn = (float)BmpHeight - 1;
    if (my_dir == OUT) {
        yup = ydn = DspHeight / 2;
        fyup = fydn = (float)BmpHeight / 2;
    // Sweep the display vertically (up or down)
    for (uint16_t y = 0; y <= DspHeight; y++) {
        if (my_dir == IN || my_dir == OUT) {
            dir = 1 - dir;
        // Prefill the pixel colors with the background color (black in this case):
        memset(PixelColor, 0, DspWidth * sizeof(*PixelColor)); // Fill background black
        // Display_image is true if the vertical sweep is withing the image boundaries:
        bool display_image;
        switch (my_dir) {
            case UP:
            case DOWN:
                display_image = y >= offset_y && y <= DspHeight - 1 - offset_y;
                break;
            case IN:
                display_image = yup >= offset_y && ydn <= DspHeight - 1 - offset_y;
                break;
            case OUT:
                display_image = ydn >= offset_y && yup <= DspHeight - 1 - offset_y;
        // Don't gather image pixels if we're not within the image boundaries.
        if (display_image) {
            bool done_x = false;
            uint32_t i = (dir == UP ? (uint32_t)(fyup + 0.5) : (uint32_t)(fydn - 0.5));
            uint32_t r = BmpImageOffset + (BmpHeight - i - 1) * (BmpWidth * BmpDepth + padding);
  // Sweep the image horizontally
            BmpFile.seek(r);
            for (uint16_t h = 0, i = 0; !done_x; h += BUFFPIXEL) {
                uint16_t size = BUFFPIXEL;
                fx = 0.0;
                if (h + size >= BmpWidth) {
                    size = BmpWidth - h;
                    done_x = true;
                BmpFile.read(SdBuffer, size * BmpDepth);
                for (uint16_t p = 0; p < size && fx + skip < (float)size; i++, p++) {
                    fx += skip;
                    uint16_t buffidx = BmpDepth * ((uint16_t)fx);
                    uint16_t x = i + offset_x;
                    switch (BmpDepth) {
                        case 1:
                            PixelColor[x] = SdBuffer[buffidx] >> 3;                     // red
                            PixelColor[x] = PixelColor[x] << 6 | (SdBuffer[buffidx] >> 2); // green
                            PixelColor[x] = PixelColor[x] << 5 | (SdBuffer[buffidx] >> 3); // blue
                            break;
                        case 3:
                            PixelColor[x] = SdBuffer[buffidx + 2] >> 3;                   // red
                            PixelColor[x] = PixelColor[x] << 6 | (SdBuffer[buffidx + 1] >> 2); // green
                            PixelColor[x] = PixelColor[x] << 5 | (SdBuffer[buffidx + 0] >> 3); // blue
                            break;
            if (dir == DOWN) {
                fydn -= skip;
            } else {
                fyup += skip;
        Tft.setCol(0, DspWidth);
        if (dir == UP) {
            Tft.setPage(yup, yup);
            yup++;
        } else {
            Tft.setPage(ydn, ydn);
            ydn--;
        Tft.sendCMD(0x2c);
        TFT_DC_HIGH;
        TFT_CS_LOW;
        for (int m = 0; m < DspWidth; m++) {
            SPI.transfer(PixelColor[m] >> 8);
            SPI.transfer(PixelColor[m]);
        TFT_CS_HIGH;
    float time_sec = (millis() - time) / 1000.0;
    Serial.print(time_sec);
    Serial.println(F(" seconds"));
boolean bmpReadHeader(File f) {
    // read header
    uint32_t tmp;
    if (read16(f) != 0x4D42) {
        Serial.println(F("Incorrect BMP file signature"));
        return false;
    // read file size
    fileSize = read32(f);
    // read and ignore creator bytes
    read16(f);
    read16(f);
    BmpImageOffset = read32(f);
    // read DIB header
    tmp = read32(f);
    BmpWidth  = read32(f);
    BmpHeight = read32(f);
    if (read16(f) != 1) {
        Serial.println("Planes != 1");
        return false;
    BmpDepth = read16(f) / 8; // Bytes / Pixel
    if (BmpDepth != 1 && BmpDepth != 3) {
        Serial.println(F("Unsupported color depth"));
        return false;
    if (read32(f) != 0) {
        Serial.println(F("compression not supported!"));
        return false;
    return true;
// These read data from the SD card file and convert them to big endian
// (the data is stored in little endian format!)
// LITTLE ENDIAN!
uint16_t read16(File f) {
    uint16_t d;
    uint8_t b;
    b = f.read();
    d = f.read();
    d <<= 8;
    d |= b;
    return d;
// LITTLE ENDIAN!
uint32_t read32(File f) {
    uint32_t d;
    uint16_t b;
    b = read16(f);
    d = read16(f);
    d <<= 16;
    d |= b;
    return d;
Last edited by adafruit_support_carter on Thu Mar 24, 2022 3:29 pm, edited 1 time in total.
Reason: added [code] tags
Re: 2.8 tft capacitive touch display
Is this the TFT display you are using?
https://www.adafruit.com/product/2090
Where did that code example come from?
JJAAWW
Post by JJAAWW »
no i'm not using that touchscreen and the code came from i think adafruit or arduino
Which display are you using? Can you link to the product page.
JJAAWW
Post by JJAAWW »
here is the link to the display that i am using
https://learn.adafruit.com/adafruit-2-8 ... 2/overview
Does the bitmap example from that guide work?
https://learn.adafruit.com/adafruit-2-8 ... ng-bitmaps
JJAAWW
Post by JJAAWW »
the graphictest works but i cant display more than 2 bmp
If you want to do that with this library:
#include "TFTv2.h"
you'll need to contact the maintainers of that library.
For the ImageReader library:
https://github.com/adafruit/Adafruit_ImageReader
you can call drawBMP() for each BMP file you want to display. For example, see how four copies of the parrot.bmp are being shown here:
https://github.com/adafruit/Adafruit_Im ... 1.ino#L127
It doesn't have to be four copies of the same file. Can call it separately for each BMP file.
