Motorshield v2: stepper motors are stuttering
goehrick
Post by goehrick »
Hey guys,
I am a beginner and face a problem with my motor shield v2 and the wired stepper motors. When I tried running different sketches where the motor is moved but never runs smooth.
I used the StepperTest sketch from examples. Can someone please tell me what I am doing wrong because I have no clue.
https://youtu.be/36QIgg-d-28
motor:
https://www.amazon.de/gp/product/B01LES ... UTF8&psc=1
#include <Wire.h>
#include "utility/Adafruit_PWMServoDriver.h"
Adafruit_StepperMotor *myMotor = AFMS.getStepper(200, 2);
  Serial.println("Stepper test!");
  AFMS.begin();
  myMotor->setSpeed(20);
  Serial.println("Single coil steps");
  myMotor->step(100, FORWARD, SINGLE);
  myMotor->step(100, BACKWARD, SINGLE);
  delay(1000);
  Serial.println("Double coil steps");
  myMotor->step(100, FORWARD, DOUBLE);
  myMotor->step(100, BACKWARD, DOUBLE);
  delay(1000);
  Serial.println("Interleave coil steps");
  myMotor->step(100, FORWARD, INTERLEAVE);
  myMotor->step(100, BACKWARD, INTERLEAVE);
  delay(1000);
  Serial.println("Microstep steps");
  myMotor->step(50, FORWARD, MICROSTEP);
  myMotor->step(50, BACKWARD, MICROSTEP);
Regards Yannic
Re: Motorshield v2: stepper motors are stuttering
Based on the motor specs, the motor you are using is intended for use with a current limiting driver. It is not compatible with the shield.
https://learn.adafruit.com/all-about-st ... he-stepper
goehrick
Post by goehrick »
adafruit_support_bill wrote:Based on the motor specs, the motor you are using is intended for use with a current limiting driver. It is not compatible with the shield.
Thank you, what motor works directly with the shield?
The #324 motor in the store is a good match for the shield: https://www.adafruit.com/product/324
We do have a current-limiting stepper driver that would work with your existing motor here: https://www.adafruit.com/product/3297
But it is limited to a 10.8v maximum supply voltage.
