BusIO error on genuino101
jdelcamp11
Post by jdelcamp11 »
After recent updates to libraries my adafruit motorshield sketches no longer compile if I use my genuino101 - other boards compile just fine.
Note: these previously worked.
This applies to all sketches using the motorshield including the example sketches from the adafruit motorshield library but only if using the genuino101.
The error is
E:\grizl\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp: In member function 'void Adafruit_I2CDevice::end()':
E:\grizl\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp:50:10: error: 'class TwoWire' has no member named 'end'
   _wire->end();
I am quessing there is something specific in the wire library for the intel/curie 101 but I don't know where to look.
Any suggestions?
jdelcamp11
Re: BusIO error on genuino101
Update: the same error appears in any sketch using I2C. (checked examples BUSIO /i2caddress_detect, INA219/getcurrent, BME280/bme280test) all fail to compile with same error.
adafruit_support_mike
It does sound like something has gone wrong in the board support package. That can happen during updates, especially if you skip a version.
The dependencies are so hard to trace that it’s easier to nuke the whole thing and start again: find your Arduino15 folder, then navigate down to ‘packages/arduino’ and delete the folder named ‘avr’. Then launch the Arduino IDE and reload the ‘Arduino AVR Boards’ package. That should put things back in order.
jdelcamp11
I tried this - not fixed.
I also deleted the intel sub-directory in arduino15. again no fix.
Also tried on two other computers with the same error on each.
Something is clearly screwed up in the libraries.. the ARV core’s Wire library defines the class TwoWire, and clearly defines the function .end():
https://github.com/arduino/ArduinoCore- ... Wire.h#L56
You may need to delete the whole IDE and install a new copy.
idranoutof1d
Post by idranoutof1d »
the Arduino 101 is not a AVR board, so the AVR library defining end() IMHO won't matter in this situation.
After struggling with the same issue, I found out this:
for some reason, while the AVR board core's Wire library defines end(), The Intel Curie base library's Wire.h does not define end().
manually adding "void end();" to Wire.h solved the problem for me.
jdelcamp11
thanks. I found the same solution.
