Two new SD libraries and the Fridge Logger
by fat16lib on Fri Jul 01, 2011 10:55 am
Edit: I have now release the new version of SdFat http://code.google.com/p/sdfatlib/downloads/list
Major versions of two SD libraries will be released soon. The libraries are my SdFat and the Arduino SD.h library. The Arduino SD library is a wrapper for an older version of SdFat.
The new version of SdFat is a major rewrite. It has many new features, improved efficiency, better error handling, improved error diagnostics, and ease of use.
As a final exercise before releasing SdFat, I decided to compare these libraries using the Adafruit "Fridge Logger" example.
I will be releasing SdFat in a day or two unless users suggest important changes or find bugs in the release candidate.
The new Arduino SD library is here https://github.com/adafruit/SD
The new version of SdFat is here http://code.google.com/p/sdfatlib/downloads/list
The Fridge Logger is here https://github.com/adafruit/Light-and-Temp-logger
The Arduino team's wrapper for SdFat was intended to make SdFat easier to use so the first exercise was to port the Fridge Logger back to the new SdFat.
The idea here is to make the minimum number of changes in the Fridge Logger and compare the two programs.
The result was that six lines needed to be changed. For details see the diff file below.
So there is little difference in terms of ease of use.
The SD.h version of the sketch is somewhat larger, 19012 bytes of flash for SD.h, and 16670 bytes for SdFat.
The main difference between the two libraries is new features. Many new features are demonstrated in the 20 new example included with SdFat.
I am also developing high speed data loggers using the new SdFat that can log as many as 40,000 samples per second.
See the fast logger beta in the new version of SdFat http://code.google.com/p/sdfatlib/downloads/list.
The new SdFat supports C++ style I/O streams in addition to the Java like print().
Below is a version of the Fridge Logger converted to I/O streams. It also has file creation and access timestamps. It detects write errors while SD.h just keeps going with no error indication.
The new SdFat has better error messages. Here is the message for an incorrectly formatted card:
Invalid format, reformat SD.
This is the message from the SD.h version of the Fridge Logger:
Initializing SD card...error: Card failed, or not present
Note the time and date for LOGGER01.CSV, which was created by the sketch below. LOGGER00.CSV was created by the Arduino SD.h library.
 Directory of G:\
01/01/2000  01:00 AM                94 LOGGER00.CSV
07/01/2011  08:03 AM             1,567 LOGGER01.CSV
               2 File(s)          1,661 bytes
               0 Dir(s)   2,032,107,520 bytes free
Diff of the two versions of the Fridge Logger.
1c1,2
< #include <SD.h>
> #include <SdFat.h>
> SdFat SD;
38c39
< File logfile;
> SdFile logfile;
72c73
<   if (!SD.begin(chipSelect)) {
>   if (!SD.init(SPI_HALF_SPEED, chipSelect)) {
84c85
<       logfile = SD.open(filename, FILE_WRITE);
>       logfile.open(filename, O_WRITE | O_CREAT);
89c90
<   if (! logfile) {
>   if (! logfile.isOpen()) {
220c221
<   logfile.flush();
>   logfile.sync();
Streams version of the Fridge Logger.
#include <SdFat.h>
#include <Wire.h>
#include "RTClib.h"
// A simple data logger for the Arduino analog pins
// how many milliseconds between grabbing data and logging it. 1000 ms is once a second
#define LOG_INTERVAL  1000 // mills between entries (reduce to take more/faster data)
// how many milliseconds before writing the logged data permanently to disk
// set it to the LOG_INTERVAL to write each time (safest)
// set it to 10*LOG_INTERVAL to write all data every 10 datareads, you could lose up to
// the last 10 reads if power is lost but it uses less power and is much faster!
#define SYNC_INTERVAL 1000 // mills between calls to flush() - to write data to the card
uint32_t syncTime = 0; // time of last sync()
#define ECHO_TO_SERIAL   1 // echo data to serial port
#define WAIT_TO_START    0 // Wait for serial input in setup()
// the digital pins that connect to the LEDs
#define redLEDpin 2
#define greenLEDpin 3
// The analog pins that connect to the sensors
#define photocellPin 0       // analog 0
#define tempPin 1            // analog 1
#define BANDGAPREF 14        // special indicator that we want to measure the bandgap
#define aref_voltage 3.3     // we tie 3.3V to ARef and measure it with a multimeter!
#define bandgap_voltage 1.1  // this is not super guaranteed but its not -too- off
// for the data logging shield, we use digital pin 10 for the sd cs line
const int chipSelect = 10;
// Serial output stream
ArduinoOutStream cout(Serial);
// file system object
SdFat sd;
// the logging file
ofstream logfile;
RTC_DS1307 RTC;  // define the Real Time Clock object
// operator that formats date/time
ostream& operator << (ostream& os, DateTime& dt) {
  os << dt.year() << '/' << int(dt.month()) << '/' << int(dt.day()) << ',';
  os << int(dt.hour()) << ':' << setfill('0') << setw(2) << int(dt.minute());
  os << ':' << setw(2) << int(dt.second()) << setfill(' ');
  return os;
// call back for file timestamps
void dateTime(uint16_t* date, uint16_t* time) {
    DateTime now = RTC.now();
  // return date using FAT_DATE macro to format fields
  *date = FAT_DATE(now.year(), now.month(), now.day());
  // return time using FAT_TIME macro to format fields
  *time = FAT_TIME(now.hour(), now.minute(), now.second());
void error(char *str) {
  // red LED indicates error
  digitalWrite(redLEDpin, HIGH);
  sd.errorHalt(str);
void setup(void) {
  Serial.begin(9600);
  // use debugging LEDs
  pinMode(redLEDpin, OUTPUT);
  pinMode(greenLEDpin, OUTPUT);
#if WAIT_TO_START
  cout << "Type any character to start" << endl;
  while (!Serial.available());
#endif //WAIT_TO_START
  // connect to RTC
  Wire.begin();
  if (!RTC.begin()) error("RTC failed");
  // set date time callback function
  SdFile::dateTimeCallback(dateTime);
  // see if the card is present and can be initialized:
  if (!sd.init(SPI_HALF_SPEED, chipSelect)) sd.initErrorHalt();
  // create a new file
  char filename[] = "LOGGER00.CSV";
  for (uint8_t i = 0; i < 100; i++) {
    filename[6] = i/10 + '0';
    filename[7] = i%10 + '0';
    if (!sd.exists(filename)) {
      // only open a new file if it doesn't exist
      logfile.open(filename);
      break;  // leave the loop!
  if (!logfile.is_open()) error("couldnt create file");
  cout <<"Logging to: " << filename << endl;
  // file header
  logfile << "millis,stamp,date,time,light,temp,vcc" << endl;
#if ECHO_TO_SERIAL
  cout << "millis,stamp,date,time,light,temp,vcc" << endl;
#endif //ECHO_TO_SERIAL
  // If you want to set the aref to something other than 5v
  analogReference(EXTERNAL);
void loop(void) {
  // milliseconds since starting
  uint32_t m = millis();
  // wait for time to be a multiple of logging interval
  do {
    m = millis();
  } while (m % LOG_INTERVAL);
  digitalWrite(greenLEDpin, HIGH);
  // fetch the time
  // read the photo cell
  analogRead(photocellPin);
  delay(10);
  int photocellReading = analogRead(photocellPin);
  // read the temperature
  analogRead(tempPin);
  delay(10);
  int tempReading = analogRead(tempPin);
  // converting that reading to voltage, for 3.3v arduino use 3.3, for 5.0, use 5.0
  float voltage = tempReading * aref_voltage / 1024;
  float temperatureC = (voltage - 0.5) * 100 ;
  float temperatureF = (temperatureC * 9 / 5) + 32;
  // Get the estimated 'VCC' voltage by measuring the internal 1.1v ref
  analogRead(BANDGAPREF);
  delay(10);
  int refReading = analogRead(BANDGAPREF);
  float supplyvoltage = (bandgap_voltage * 1024) / refReading;
  // log the data
  logfile << m << ',' << now.unixtime() << ',' << now;
  logfile << ',' << photocellReading << ',' << temperatureF;
  logfile << ',' << supplyvoltage << endl;
#if ECHO_TO_SERIAL
  cout << m << ',' << now.unixtime() << ',' << now;
  cout << ',' << photocellReading << ',' << temperatureF;
  cout << ',' << supplyvoltage << endl;
#endif // ECHO_TO_SERIAL
  digitalWrite(greenLEDpin, LOW);
  // Now we write data to disk! Don't sync too often
  // requires 2048 bytes of I/O to sd card
  // which uses a bunch of power and takes time
  if ((millis() - syncTime) >= SYNC_INTERVAL) {
    syncTime = millis();
    // blink LED to show we are syncing data to the card & updating FAT!
    logfile.flush();
    digitalWrite(redLEDpin, LOW);
  // check for errors
  if (!logfile.good()) error("write error");
fat16lib
Re: Two new SD libraries and the Fridge Logger
by bvernham on Sun Nov 24, 2013 6:36 pm
"The new SdFat supports C++ style I/O streams in addition to the Java like print()."
I tried using:
logfile.print() but when tried to compiled is said that the print object did not exist.
I thought logfile.print still worked?
Bruce
bvernham
