Due to high demand and inclement weather, expect some shipping delays at this time, orders may not ship for 4-5 business days.
Wave Shield voltage change with audio levels
by Raythe54 on Sun Sep 16, 2012 11:49 pm
Sorry for the newbie question.
I'm trying to find out where best to get voltage changes with audio level on a Wave Shield to link into an Analog In. An Instructable I'm attempting to follow shows linking R7 to an input should do it, but I don't see the voltage fluctuate on my digital meter.
Any idea if this should work or if there's a better place to tap off of?
Thanks, in advance,
Ray
Raythe54
Re: Wave Shield voltage change with audio levels
by adafruit_support_bill on Mon Sep 17, 2012 5:56 am
R7 is a good place to tap into the signal. But you won't be able to see much with your multimeter because the signal is changing too fast for the multimeter to measure.
by adafruit_support_rick on Mon Sep 17, 2012 6:04 am
input voltages will be very low. If you just want to feed it into an ADC, you'd be better off sampling the output voltages going to the speaker.
Have a look around C9. For input to the ADC, use a diode to get only the positive voltages (music signals will be pretty much symmetrical, so you can simply sample half the waveform and extrapolate).
by Raythe54 on Mon Sep 17, 2012 11:24 am
I'll look into that - thanks a million for the reply!
Raythe54
