📣📪 🚚 Adafruit will not be shipping USPS orders Monday January 20, 2020 🗓. Expedited USPS orders placed after 11am ET 🕚 Friday January 17 will go out Tuesday January 21 📣📪🚚
Motor Shield + NRF24L01
by tribun on Thu Mar 27, 2014 5:24 am
Hey,
I am Using an Arduino Uno and the Motor Shield v2.0. Now I attached a nrf24l01+ to the shield and thought it would work like without the shield between, but it doesnt.
Now I figured out that the shield uses SPI (?) to communicate with the board. And the nrf24l01+ thing also uses SPI (Pins 13,12,11). So may be this is the problem? That both are using the same lines?
I feel very bad that I don't understand whats going on and how SPI works.. so please excuse my newby question, but:
Can someone please explain if SPI is the problem?
And what I can do to get both to work?
Kind regards
Patrick
tribun
Re: Motor Shield + NRF24L01
by adafruit_support_bill on Thu Mar 27, 2014 7:04 am
The V2 board does not use SPI. It does not use pins 11, 12 or 13 for anything. These are passed straight-through in the headers.
Please post a photo of your setup.
by tribun on Thu Mar 27, 2014 3:04 pm
Ok, I took fotos which are hopefully attached to this post..
I tested the lines and tested also that there is no connection to one another.
The software seems ok since when I connect the exact same Transmitter direktly to the Arduino without the shield it is working (I had to change the CE-Pin to 6, instead of 8).
But even though everything else (which you can see in the picture) is disconnected, I got only the first package sent. The next attemt to call Mirf.send() it hangs forever.
What is wrong? Is any of those PINs not usable within the Motor Shield v2? Please help me...
tribun
by adafruit_support_bill on Thu Mar 27, 2014 4:02 pm
None of those pins (other than the GND pin) are used by the shield. If one packet is getting through, then you are obviously talking to the RF card. You may have an intermittent solder joint somewhere or possibly some RF interference from the PWM. Post the code you are using and a photo of the back-side of the board.
by tribun on Fri Mar 28, 2014 4:44 am
you are my hero!
"intermittent solder joint" was the right suggestion. After reading that, and with the information that it SHOULD work like this, I re-soldered the connections and voilá - now it works.
thank you very much! :)
tribun
by AbdElhalimWahid on Thu Jul 11, 2019 5:30 pm
ImageHey there,
Glade your problem solved.
I want to build arduino car with l293d shield( the one its image attached) and nrf24l01 module, I really need help with the code. So If you have an idea how to build it I will be grateful.
AbdElhalimWahid
by adafruit_support_bill on Thu Jul 11, 2019 6:18 pm
@AbdElhalimWahid - That is a Sunfounder shield. Sunfounder should be able to assist you with any technical questions.
