Free Pins with Motor Shield
by cmpalmer on Tue Feb 26, 2008 3:56 pm
I just got my motor shield kit yesterday and haven't had a chance to build it it, but I I have a question (that hopefully won't be obvious once I start looking at the kit).
Which analog and digital pins will I still have available for other uses if I'm using the motor shield? I see that the analog pins are brought up and there is a space to solder a female header there, but what about the digital pins?
cmpalmer
by adafruit on Tue Feb 26, 2008 6:51 pm
you should take a look at the schematic, all the analog pins are available but i dont remember which digital ones
by cmpalmer on Tue Feb 26, 2008 7:04 pm
It looks like just 0 and 1 (serial TX/RX) and pin 13 if I'm reading it right.
No big deal (and I know you can use the analog pins as digital inputs as well), I was just curious...
cmpalmer
by Selaseth on Mon May 05, 2008 6:18 pm
You can use most of the analog pins - you can even use them als digital input or outputs as pinMode(14, INPUT) for analog pin 0: http://www.arduino.cc/en/Tutorial/AnalogInputPins
I've tested it with a switch to start a servo..
-Eddi
Selaseth
