hello, I'm trying to make a simple switch case mp3 player with this shield. this is my first day with it and this is my code maded of cut and paste. obviously it doesn't work. any suggestion?
#include <SPI.h>
#include <Adafruit_VS1053.h>
#include <SD.h>
#define SHIELD_RESET 9 // VS1053 reset pin (output)
//#define BREAKOUT_CS 10 // VS1053 chip select pin (output)
//#define BREAKOUT_DCS 8 // VS1053 Data/command select pin (output)
// These are the pins used for the music maker shield
#define SHIELD_CS 7 // VS1053 chip select pin (output)
#define SHIELD_DCS 6 // VS1053 Data/command select pin (output)
// These are common pins between breakout and shield
#define CARDCS 4 // Card chip select pin
// DREQ should be an Int pin, see http://arduino.cc/en/Reference/attachInterrupt
#define DREQ 3 // VS1053 Data request, ideally an Interrupt pin
Adafruit_VS1053_FilePlayer musicPlayer =
// create breakout-example object!
//Adafruit_VS1053_FilePlayer(BREAKOUT_RESET, BREAKOUT_CS, BREAKOUT_DCS, DREQ, CARDCS);
// create shield-example object!
Adafruit_VS1053_FilePlayer(SHIELD_RESET, SHIELD_CS, SHIELD_DCS, DREQ, CARDCS);
const int sensorMin = 0; // sensor minimum, discovered through experiment
const int sensorMax = 600; // sensor maximum, discovered through experiment
// initialize serial communication:
Serial.begin(9600);
Serial.begin(9600);
Serial.println("Adafruit VS1053 Simple Test");
if (! musicPlayer.begin()) { // initialise the music player
Serial.println(F("Couldn't find VS1053, do you have the right pins defined?"));
while (1);
Serial.println(F("VS1053 found"));
SD.begin(CARDCS); // initialise the SD card
// Set volume for left, right channels. lower numbers == louder volume!
musicPlayer.setVolume(20,20);
// Timer interrupts are not suggested, better to use DREQ interrupt!
//musicPlayer.useInterrupt(VS1053_FILEPLAYER_TIMER0_INT); // timer int
// If DREQ is on an interrupt pin (on uno, #2 or #3) we can do background
// audio playing
musicPlayer.useInterrupt(VS1053_FILEPLAYER_PIN_INT); // DREQ int
// Play one file, don't return until complete
Serial.println(F("Playing track 001"));
musicPlayer.playFullFile("track001.mp3");
// Play another file in the background, REQUIRES interrupts!
Serial.println(F("Playing track 002"));
musicPlayer.startPlayingFile("track002.mp3");
// read the sensor:
int sensorReading = analogRead(A0);
// map the sensor range to a range of four options:
int range = map(sensorReading, sensorMin, sensorMax, 0, 2);
// do something different depending on the
// range value:
switch (range) {
case 0: // your hand is on the sensor
Serial.println("dark");
musicPlayer.stopPlaying();
break;
case 1: // your hand is close to the sensor
Serial.println("dim");
musicPlayer.pausePlaying(true);
break;
case 2: // your hand is a few inches from the sensor
Serial.println("medium");
musicPlayer.pausePlaying(false);
break;
delay(1); // delay in between reads for stability
yes, you're right. I've spent a couple of hour to understand that this shield doen't work well on arduino 2009 and I'm a little tired. :-)
This library is new for me, in the previous code I was trying to make a simple pause and start for a track using an analog value.
#include <SPI.h>
#include <SD.h>
const int sensorMax = 1023;
Serial.begin(9600);
Serial.begin(9600);
while (1);
// audio playing
musicPlayer.startPlayingFile("track001.mp3");
int range = map(sensorReading, sensorMin, sensorMax, 0, 1);
switch (range) {
case 0:
Serial.println("1");
musicPlayer.pausePlaying(false);;
break;
case 1:
Serial.println("2");
break;
delay(100);
#include <SPI.h>
#include <SD.h>
const int val = 0;
Serial.begin(9600);
Serial.begin(9600);
while (1);
//musicPlayer.setVolume(10,100);
// audio playing
int val = analogRead(A0);
analogWrite ;musicPlayer.setVolume(val*100/1000,val*100/1000);
int range = map(val, sensorMin, sensorMax, 0, 1);
switch (range) {
case 0:
break;
case 1:
break;
delay(100);
