minor error on PCB
minor error on PCB
by cairn on Fri Apr 11, 2008 3:07 pm
I didn't see this reported anywhere else, and I'm not sure if the forum is the best place for this, but I found a small error on the Motor Shield PCB when I put it together last night. The labels for the optional 5V and GND headers next to the analog pin headers are switched around; the one labeled 5V is actually ground and vice versa. Not too big a deal. Great shield design BTW, very versatile!
cairn
by adafruit on Fri Apr 11, 2008 4:00 pm
eek! thanks for the note.
May have another
by avalonbeer on Tue Apr 15, 2008 10:47 am
This is my first post and am still learning about the hardware side of the wonderful Arduino Decimila and your equally wonderful Motor Shield.
I soldered up the V1.0 and have been testing it with a small dc motor. M1 & M2 are fine, but I had a bit of a scare when I tried M3 & M4. It seems that the lettering on the pcb has them reversed. M3 is labeled as closer to the analog pins with M4 being closer to the Digital pins.
When I ran the sample sketch for those two outputs:
AF_DCMotor motor(4, MOTOR34_8KHZ);
fired up the motor closer to the analog pins.
The reverse occured when calling Motor 3.
This looks like it could be repaired by modifying the #define statements in afmotor.h which look like:
#define MOTOR1_A 2
#define MOTOR1_B 3
#define MOTOR2_A 1
#define MOTOR2_B 4
#define MOTOR3_A 0
#define MOTOR3_B 6
#define MOTOR4_A 5
#define MOTOR4_B 7
Next I get to try and figure out some steppers from the junk box. They are a bit more daunting. Servo's are after that.
avalonbeer
by avalonbeer on Tue Apr 15, 2008 10:53 am
Never mind...
5 Minutes after posting this I saw in the "Motor Trouble" post that I'm a month late in reporting this.
avalonbeer
