Demonstrates using an UNO with v.2 Touch Shield to create a miniature keyboard:
http://youtu.be/3z3sUzaF4wo
2.8" TFT Touch Shield Keyboard
- Franklin97355
Re: 2.8" TFT Touch Shield Keyboard
Nice job. Perhaps you could post up a description of how it was accomplished. I'm sure others are interested.
- asteroid
This demo is a modification of Clay Furman's work (inspired by an Adafruit tutorial) found on the Arduino website. Hardware is described in the video. Arduino sketch follows:
UNO + 2.8" TFT Touch Shield v.2 (Adafruit)
USB on right
Known problem: all notes are same duration
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_ILI9341.h>
#include <Adafruit_STMPE610.h>
// Default values for Adafruit shield v2.
#define STMPE_CS 8
#define TFT_DC 9
#define TFT_CS 10
Adafruit_STMPE610 ts = Adafruit_STMPE610(STMPE_CS);
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
// Assign human-readable names to some common 16-bit color values:
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
// Pin to which the speaker is connected
// Use 19 for UNO (A5 pin, as a digital output)
const int speaker = 19;
//Frequencies for notes
#define NOTE_C4 262
#define NOTE_CS4 277
#define NOTE_D4 294
#define NOTE_DS4 311
#define NOTE_E4 330
#define NOTE_F4 349
#define NOTE_FS4 370
#define NOTE_G4 392
#define NOTE_GS4 415
#define NOTE_A4 440
#define NOTE_AS4 466
#define NOTE_B4 494
#define NOTE_C5 523
#define NOTE_CS5 554
#define NOTE_D5 587
#define NOTE_DS5 622
#define NOTE_E5 659
#define TS_MINX 150
#define TS_MINY 130
#define TS_MAXX 3800
#define TS_MAXY 4000
#define color BLUE
int counter;
const int bKeyW = 20;
const int bKeyH = 140;
const int wKeyW = tft.height()/10;
const int wKeyH = tft.width();
const int spacing = 4;
int duration = 300; //Default time to wait between notes
void drawKeys()
//Draw the white keys
for (int i = 0; i < 11; i++) {
tft.fillRect( 0, i*wKeyW, wKeyH, wKeyW-spacing, WHITE );
//Draw the black keys
tft.fillRect( 0, wKeyW - bKeyW/2 - spacing/2, bKeyH, bKeyW, BLACK );
tft.fillRect( 0, 2*wKeyW - bKeyW/2 - spacing/2, bKeyH, bKeyW, BLACK );
tft.fillRect( 0, 4*wKeyW - bKeyW/2 - spacing/2, bKeyH, bKeyW, BLACK );
tft.fillRect( 0, 5*wKeyW - bKeyW/2 - spacing/2, bKeyH, bKeyW, BLACK );
tft.fillRect( 0, 6*wKeyW - bKeyW/2 - spacing/2, bKeyH, bKeyW, BLACK );
tft.fillRect( 0, 8*wKeyW - bKeyW/2 - spacing/2, bKeyH, bKeyW, BLACK );
tft.fillRect( 0, 9*wKeyW - bKeyW/2 - spacing/2, bKeyH, bKeyW, BLACK );
void setup()
tft.begin();
ts.begin();
tft.fillScreen(BLACK);
counter = 0;
drawKeys();
void loop()
uint16_t x, y;
uint8_t z;
//hang around in a while loop until the touch is released
if (ts.touched()) {
while (! ts.bufferEmpty())
counter++;
ts.readData(&x, &y, &z);
x = map( x, TS_MINY, TS_MAXY, 0, tft.width());
y = map( y, TS_MINX, TS_MAXX, 0, tft.height());
if (counter < 2) {
if(x < 140)
{ // For sharps/flats split Y axis into black and white keys
if (y>=290 && y<=312) tone(speaker,NOTE_C4);
if (y>=256 && y<=283) tone(speaker,NOTE_CS4);
if (y>=264 && y<=275) tone(speaker,NOTE_D4);
if (y>=245 && y<=260) tone(speaker,NOTE_DS4);
if (y>=220 && y<=244) tone(speaker,NOTE_E4);
if (y>=199 && y<=219) tone(speaker,NOTE_F4);
if (y>=181 && y<=196) tone(speaker,NOTE_FS4);
if (y>=168 && y<=178) tone(speaker,NOTE_G4);
if (y>=147 && y<=164) tone(speaker,NOTE_GS4);
if (y>=136 && y<=146) tone(speaker,NOTE_A4);
if (y>=117 && y<=132) tone(speaker,NOTE_AS4);
if (y>=93 && y<=113) tone(speaker,NOTE_B4);
if (y>=70 && y<=90) tone(speaker,NOTE_C5);
if (y>=53 && y<=66) tone(speaker,NOTE_CS5);
if (y>=41 && y<=57) tone(speaker,NOTE_D5);
if (y>=22 && y<=35) tone(speaker,NOTE_DS5);
if (y>=0 && y<=18) tone(speaker,NOTE_E5);
delay(duration);
noTone(speaker);
} else {
// Otherwise, split Y axis into white keys only
if (y>=289 && y<=313) tone(speaker,NOTE_C4);
if (y>=257 && y<=281) tone(speaker,NOTE_D4);
if (y>=224 && y<=251) tone(speaker,NOTE_E4);
if (y>=191 && y<=217) tone(speaker,NOTE_F4);
if (y>=160 && y<=187) tone(speaker,NOTE_G4);
if (y>=127 && y<=154) tone(speaker,NOTE_A4);
if (y>=95 && y<=122) tone(speaker,NOTE_B4);
if (y>=65 && y<=91) tone(speaker,NOTE_C5);
if (y>=31 && y<=59) tone(speaker,NOTE_D5);
if (y>=2 && y<=26) tone(speaker,NOTE_E5);
delay(duration);
noTone(speaker);
ts.writeRegister8(STMPE_INT_STA, 0xFF); // reset all ints
} else {counter = 0;}
- asteroid
New improved Arduino sketch will sustain note while key is down. Notes are no longer a fixed duration.
UNO + 2.8" TFT Touch Shield v2
Demonstrates a miniature keyboard
Note will sustain while key is down
#include <SPI.h>
#include <Wire.h>
#define STMPE_CS 8
#define TFT_DC 9
#define TFT_CS 10
#define BLUE 0x001F
#define RED 0xF800
#define CYAN 0x07FF
#define NOTE_C4 262
#define NOTE_D4 294
#define NOTE_E4 330
#define NOTE_F4 349
#define NOTE_G4 392
#define NOTE_A4 440
#define NOTE_B4 494
#define NOTE_C5 523
#define NOTE_D5 587
#define NOTE_E5 659
#define TS_MINX 150
#define TS_MINY 130
void drawKeys()
void setup()
// Serial.begin(9600);
tft.begin();
ts.begin();
drawKeys();
void loop()
uint16_t x, y;
TS_Point p = ts.getPoint();
if (! ts.touched()) {
noTone(speaker);
return;
delay(100);
p = ts.getPoint();
x = map( p.x, TS_MINY, TS_MAXY, 0, tft.width());
y = map( p.y, TS_MINX, TS_MAXX, 0, tft.height());
// *** For debugging *** //
Serial.print("X = "); Serial.print(x);
Serial.print("\tY = "); Serial.println(y);
Serial.println("================");
while (ts.touched()) {
if(x < 140)
if (y>=291 && y<=310) tone(speaker,NOTE_C4);
if (y>=276 && y<=290) tone(speaker,NOTE_CS4);
if (y>=262 && y<=275) tone(speaker,NOTE_D4);
if (y>=195 && y<=217) tone(speaker,NOTE_F4);
if (y>=178 && y<=193) tone(speaker,NOTE_FS4);
if (y>=161 && y<=177) tone(speaker,NOTE_G4);
if (y>=144 && y<=160) tone(speaker,NOTE_GS4);
if (y>=128 && y<=143) tone(speaker,NOTE_A4);
if (y>=111 && y<=127) tone(speaker,NOTE_AS4);
if (y>=89 && y<=110) tone(speaker,NOTE_B4);
if (y>=67 && y<=88) tone(speaker,NOTE_C5);
if (y>=51 && y<=66) tone(speaker,NOTE_CS5);
if (y>=36 && y<=50) tone(speaker,NOTE_D5);
if (y>=21 && y<=35) tone(speaker,NOTE_DS5);
if (y>=0 && y<=20) tone(speaker,NOTE_E5);
} else {
