Stepper Speed limitations with MotorShield v2?
Re: Stepper Speed limitations with MotorShield v2?
by mccarthybergeron on Mon Jul 21, 2014 1:38 pm
Yes it does.
mccarthybergeron
by adafruit_support_bill on Mon Jul 21, 2014 1:56 pm
So the gearing is correct.
In the code you posted, you are using AccelStepper to drive the motor. As I mentioned earlier, AccelStepper adds some overhead of its own which we do not control. It also (as the name suggests) uses acceleration to produce smooth motion. If you set a speed and tell it to move a motor, it will gradually accelerate to the specified speed, so it will take longer to reach the programmed RPM.
by mccarthybergeron on Mon Jul 28, 2014 10:12 am
Have you figured out the stepper-rate limits by any chance? Was hoping to find out this before moving onto a different strategy.
mccarthybergeron
by mccarthybergeron on Mon Jul 28, 2014 10:18 am
Also, judging by your prior remarks, a stepper with a 7.5 degree step vs 1.8 degree step (assuming V, Amps, etc are equivalent) will be able to achieve a higher RPM on this shield since the PPS (Pulse Per Second) would be the same? And from what I understand, the Motor Shield delivers a constant voltage and applies a variable amount of current to turn the stepper one step? And the current delivered to the device, is that "automatically" determined when we issue the command oneStep()?
mccarthybergeron
by adafruit_support_bill on Mon Jul 28, 2014 11:02 am
I have a couple of other projects on the bench that I need to finish up before I can get to it. Possibly sometime this week.
That is true of any shield or driver. Whether limited by communication bandwidth or phase inductance, all driver/motor systems have a step-rate limit. All else being equal, a low-step count motor can be driven to higher RPMs.
That is true for microstepping mode. The shield generates a pseudo sine-wave microstep profile via PWM. In all other stepping modes, the shield applies a constant voltage. The actual current draw is a function of the phase impedence and will be lower at higher step-rates.
by adafruit_support_bill on Tue Jul 29, 2014 10:19 am
OK. Some preliminary numbers:
Based on the default i2c clock-rate, the maximum step-rate in DOUBLE step mode is ~263 steps/second.
by mccarthybergeron on Tue Jul 29, 2014 3:35 pm
Huh - that seems to be pretty close to what I get. Do you plan on modifying the bus speed to see the performance step difference?
Thanks again for your time with this.
mccarthybergeron
by adafruit_support_bill on Tue Jul 29, 2014 8:42 pm
With the i2c bus speed increase, I get 773 steps/sec. I think there is still room for improvement by eliminating the microstep overhead.
by adafruit_support_bill on Wed Jul 30, 2014 4:33 pm
And some more numbers:
With the microstepping PWM overhead stripped out, the max step rate is 1161 steps/second.
I was not able to get the #324 200-step motor to run at that speed : https://www.adafruit.com/products/324
I had to slow the step rate down to about 830 steps/second. (Any faster and it would start missing steps) That translates into about 250 RM.
Mind you, that is right at the limit for this particular motor powered by a good stiff bench supply @12v. Your mileage may vary.
To replicate this, you need to hack the library a bit.
Add this function prototype to the Adafruit_StepperMotor class in Adafruit_MotorShield.h
  uint8_t quickstep(uint8_t dir);
Then add this function to the end of Adafruit_MotorShield.cpp
uint8_t Adafruit_StepperMotor::quickstep(uint8_t dir) {
  uint8_t a, b, c, d;
  uint8_t ocrb, ocra;
  ocra = ocrb = 255;
  // DOUBLE step only
    if (! (currentstep/(MICROSTEPS/2) % 2)) { // we're at an even step, weird
      if (dir == FORWARD) {
   currentstep += MICROSTEPS/2;
      } else {
   currentstep -= MICROSTEPS/2;
    } else {           // go to the next odd step
   currentstep += MICROSTEPS;
      } else {
   currentstep -= MICROSTEPS;
  currentstep += MICROSTEPS*4;
  currentstep %= MICROSTEPS*4;
#ifdef MOTORDEBUG
  Serial.print("current step: "); Serial.println(currentstep, DEC);
  Serial.print(" pwmA = "); Serial.print(ocra, DEC);
  Serial.print(" pwmB = "); Serial.println(ocrb, DEC);
#endif
  // release all
  uint8_t latch_state = 0; // all motor pins to 0
    switch (currentstep/(MICROSTEPS/2)) {
    case 0:
      latch_state |= 0x1; // energize coil 1 only
      break;
    case 1:
      latch_state |= 0x3; // energize coil 1+2
      break;
    case 2:
      latch_state |= 0x2; // energize coil 2 only
      break;
    case 3:
      latch_state |= 0x6; // energize coil 2+3
      break;
    case 4:
      latch_state |= 0x4; // energize coil 3 only
      break;
    case 5:
      latch_state |= 0xC; // energize coil 3+4
      break;
    case 6:
      latch_state |= 0x8; // energize coil 4 only
      break;
    case 7:
      latch_state |= 0x9; // energize coil 1+4
      break;
#ifdef MOTORDEBUG
  Serial.print("Latch: 0x"); Serial.println(latch_state, HEX);
#endif
  if (latch_state & 0x1) {
   // Serial.println(AIN2pin);
    MC->setPin(AIN2pin, HIGH);
  } else {
    MC->setPin(AIN2pin, LOW);
  if (latch_state & 0x2) {
    MC->setPin(BIN1pin, HIGH);
   // Serial.println(BIN1pin);
  } else {
    MC->setPin(BIN1pin, LOW);
  if (latch_state & 0x4) {
    MC->setPin(AIN1pin, HIGH);
   // Serial.println(AIN1pin);
  } else {
    MC->setPin(AIN1pin, LOW);
  if (latch_state & 0x8) {
    MC->setPin(BIN2pin, HIGH);
   // Serial.println(BIN2pin);
  } else {
    MC->setPin(BIN2pin, LOW);
  return currentstep;
Call "onestep(FORWARD, DOUBLE);" once in your setup function to initialize the PWM to 100%. Then call "quickstep(FORWARD);" in your loop. You can adjust the delayMicroseconds to control the speed.
void loop()
  long start = millis();
  for (int i = 0; i < 10000; i++)
    myMotor2->quickstep(FORWARD);
    delayMicroseconds(325);
  Serial.println(millis() - start);
by mccarthybergeron on Wed Jul 30, 2014 5:11 pm
Bill - you rock. I'll be playing with this very soon. Thanks again for your support.
BTW - kudos to the person who came up with the resistor form submission catcher. Great metaphor and pun, and just cool all around.
mccarthybergeron
by karpukhin on Mon Aug 11, 2014 3:13 am
Bill, thank you. Could you also post the code and instruction for the i2c bus clock speed increase, please?
karpukhin
by adafruit_support_bill on Mon Aug 11, 2014 6:19 am
https://learn.adafruit.com/adafruit-mot ... rduino/faq
The default bus speed is 100KHz and can be increased to 400KHz by editing the library file in your Arduino installation folder. The file can be found in hardware/libraries/wire/utility/twi.h.
Find the line with: "#define TWI_FREQ 100000L"
and change it to "#define TWI_FREQ 400000L"
Or, you can add the following code to your setup() function:
TWBR = ((F_CPU /400000l) - 16) / 2; // Change the i2c clock to 400KHz
by mccarthybergeron on Thu Aug 21, 2014 9:06 pm
Gotta say, you rock. I played with the code and even created a slightly different class using what you had and the Accelerator code and the motors spun much, much faster. Huge improvement and I just completed the project I was working on for a client. Thanks a ton!
mccarthybergeron
by wergor on Sun Sep 07, 2014 9:38 am
adafruit_support_bill wrote:https://learn.adafruit.com/adafruit-motor-shield-v2-for-arduino/faq
adding this line to my setup() does not increase the maximum stepper speed, i have to set TWI_FREQ to 400000L in the twi.h. i'm using a mega2560.
adafruit_support_bill wrote:And some more numbers:
will this be added to the official library?
wergor
by adafruit_support_bill on Sun Sep 07, 2014 11:04 am
Add it after the call to 'begin()'. Otherwise it gets reset to the default speed.
