Stepper Speed limitations with MotorShield v2?
Re: Stepper Speed limitations with MotorShield v2?
by Kushal11 on Mon Apr 11, 2016 7:09 pm
Another question...
Mine is a 200 steps/rev motor.
These are the settings for Double mode. Speed is in steps per second.
stepper2.setMaxSpeed(500.0);
  stepper2.setAcceleration(500.0);
  stepper2.moveTo(200);
This takes around 7 seconds to compete 5 revs.
Now these are the same settings but for Microstep mode (1/16th of full step). Again, speed is in microsteps per second.
  stepper2.moveTo(3200);  //for microstep, it's 3200 steps/rev
This takes around 37 seconds to compete 5 revs. (which is around 5 times slower than double step mode )
Now, if my microstep mode uses 1/16th of a full step, shouldn't my speed in microstep mode be 16 times slower than the speed in double step mode?
Kushal11
by adafruit_support_bill on Mon Apr 11, 2016 7:45 pm
That is probably a question for the AccelStepper folks. I don't know much about their internals and how they calculate timing for microstepping.
by Kushal11 on Mon Apr 11, 2016 7:58 pm
Ok, thanks Bill.
And after reaching to desired position, what if I want to power off the stepper to save power? My stepper has enough detent torque to hold the load w/o power.
I tried enable/disableOutputs() in this way...
void setup()
  Serial.begin(9600);
  while (Serial.available() == 0)
  if (Serial.available() > 0)
    i = Serial.read();
    stepper2.enableOutputs ();
  AFMStop.begin(); // Start the top shield
  TWBR = ((F_CPU /800000l) - 16) / 2; // Change the i2c clock to 800KHz
  stepper2.moveTo(difference*200);
void loop()
   if (stepper2.distanceToGo() == 0)
    stepper2.disableOutputs ();
    stepper2.run();
But not working :( Definitely I am missing something (probably many things!), what's that?
Kushal11
by adafruit_support_bill on Mon Apr 11, 2016 8:25 pm
The AcclStepper disableOutputs() function doesn't work with the motor shield. But you can call 'release()' on the underlying Adafruit stepper object.
by Kushal11 on Thu Apr 14, 2016 12:00 pm
Thanks Bill. It worked!
Kushal11
by Kushal11 on Wed May 11, 2016 2:10 pm
Bill, so why do we need to increase the i2c bus speed?
If the shield's PCA9685 is really a free running driver, then we only need to set it's parameters (PWM freq, duty cycle, etc) by i2c once and then it can run the stepper on its own. I2C speed shouldn't need to be more than the speed at which the user changes the commands. PWM frequency of the PCA9685 should be the one who can help us achieve higher RPMs.
Am I missing something here?
Kushal11
by adafruit_support_bill on Wed May 11, 2016 2:34 pm
No. That is not how things work.
It takes more than just a PWM pulse to control a stepper motor. You need 2 signals per bridge to create the bipolar signal for each phase. You also need a PWM signal to control the duty cycle on each phase (for microstepping). Each step potentially involves changing all 6 signals per motor. The "quickStep()" optimization above reduces that traffic somewhat by eliminating the PWM control. This also effectively eliminates microstepping capability..
by citfta on Fri Jul 29, 2016 4:53 pm
I have the Nema 17 motor and the Adafruit Feather MotorShield V2 board. I have it working with the sample test code. Now I want to speed up the motor and have read all of this thread a couple of times until I was pretty sure I understood what I needed to do. When I get to the library and open the MotorShield sketch I can add the new code using copy and paste from this thread. But when I try to save it I get an error that says access denied. I am using WordPad (Windows 7) and I have administrative privileges for anything else I want to do. Do I need some other program to edit the sketches in the library? Thanks for any help you can give.
citfta
by adafruit_support_bill on Fri Jul 29, 2016 5:04 pm
The file probably has read-only attributes. If you right-clck and select Properties, you should be able to un-check the Read Only box.
by citfta on Fri Jul 29, 2016 6:58 pm
Thank you for your very quick reply. I did right click on the files and neither the .h file or the .cpp file were write protected. The properties box said they might be blocked and gave me an option to unblock them. I tried that but am still not able to save the files after I add the needed code to speed up my stepper motor. I am copying and pasting from this thread.
citfta
by citfta on Fri Jul 29, 2016 9:54 pm
Ok I found a way to edit the library files. I had to install a C++ editor and that let me add the new lines from this thread and save the edited files. The editor I used is called Dev C++. It seemed very easy to use for just editing a file. Thanks for the suggestions.
citfta
by adafruit_support_bill on Sat Jul 30, 2016 5:50 am
Good to hear that you found a solution. Not sure why WordPad would not do it.
by jbc on Tue Oct 11, 2016 8:44 pm
I amended the files Bill mentioned here;
https://forums.adafruit.com/viewtopic.php?f=31&t=57041&start=15
I got lost with this step;
Call "onestep(FORWARD, DOUBLE);" once in your setup function to initialize the PWM to 100%. Then call "quickstep(FORWARD);" in your loop. You can adjust the delayMicroseconds to control the speed.
I am using my own sketch and tried to place the above in it in different places including the top/beginning of the sketch (right after the motor shield libraries are called.
I am trying to get more power from the stepper motors connected to the motor shields V2.
Right now they are too weak. I found this thread but need help progressing.
jbc
jbc
by adafruit_support_bill on Wed Oct 12, 2016 5:39 am
This thread is about increasing speed. With stepper motors, torque will decrease with speed. Better to start a new thread for this topic.
posting.php?mode=post&f=31
by scottferg on Thu Dec 15, 2016 3:34 pm
Bill pointed me to this thread and I thought I'd share my experiences here as well.
I've hacked the Adafruit_StepperMotor class to cache the 'latch' and 'pwm' values in the 'onestep' function so that they are transmitted by i2c only when they change. This eliminates a significant number of 12c transmissions rather than just speeding them up. This is essentially the contribution of the 'quickstep' hack, but caching makes the optimization available to ALL stepping styles, not just DOUBLE, and without a separate function. This caching resulted, for my case, in about a 25% improvement in calls/sec to loop(), yielding higher possible stepping frequencies. I tried increasing i2c speed to 400kHz and even 500kHz (verified by printing TWBR within loop()) but did not notice any further significant improvements.
I also applied a trivial hack to the AccelStepper library to use microsecond timing rather than millisecond timing, which significantly improved it's calculations and thus the correlation between it's report of stepper speed with the values I see empirically. I.e. without this hack I was observing actual speeds less than those being requested!
scottferg
