Getting the Motor shield up and running, w/o error code
by richile on Sun May 04, 2008 2:20 pm
I copied the AF Motor code the Arduino window, and this error came up:
o: In function `main':
undefined reference to `setup'
What can I do to make this go away? I'm new to this so be gentle.
richile
by franklin97355 on Sun May 04, 2008 4:42 pm
Did you follow these steps?
Install the ServoTimer1 library as indicated on its webpage
Make sure you include <ServoTimer1.h>
Create a ServoTimer1 object for each servo you want (up to 2)
Attach the servos to pin 9 (servo A) or 10 (servo B) using attach()
Finally, when you want to set the position of the servo, simply use write(ANGLE) where ANGLE ranges from 0 to 180. 90 is "dead center" for position-servos and "not moving" for continuous-rotation servos.
franklin97355
by richile on Mon May 05, 2008 5:55 pm
Great, thank you. It is working now. Next question: If I want to run a second dc motor would there be a second line under?;
AF_DCMotor motor(2, MOTOR12_64KHZ); // create motor #2, 64KHz pwm
as in;
AF_DCMotor motor(1, MOTOR12_64KHZ); // create motor #1, 64KHz pwm
richile
by adafruit on Tue May 06, 2008 8:17 pm
yes
each motor must be instantiated in that way
