Com problems again
Com problems again
by richile on Tue May 06, 2008 11:43 am
I had the stepper motor running fine. Disconnected motor to check resistance then reconnected. Did not run and then I tried to ulpoad to board (several times) when I received this error:
avrdude: stk500_recv(): programmer is not responding
I have not changed the usb (checked it) tried all of the other trouble shooting suggestion, also quit app and restart computer to no avail.
Any possible resolutions?
richile
by trialex on Tue May 06, 2008 8:03 pm
Sounds like the chip got corrupted - easy to do when connecting various loads to pins.
Have you got a programmer to re-flash the bootloader?
trialex
by adafruit on Tue May 06, 2008 8:19 pm
i would unplug the motor shield
power down, then make sure you're powering the board properly
and try again
by richile on Wed May 07, 2008 2:59 pm
ladyada wrote:i would unplug the motor shield
and try again
Done that Many times and no response.
richile
by richile on Wed May 07, 2008 3:01 pm
trialex wrote:Sounds like the chip got corrupted - easy to do when connecting various loads to pins.
No programmer should I get a new AtMega? Where do I get the bootloader from?
richile
by adafruit on Wed May 07, 2008 3:44 pm
never heard of a motor frying the bootloader so im wondering whats up. regardless you can burn your own bootloader if you have a chip programmer or i have them in the adafruit.com shop
by richile on Wed May 07, 2008 6:15 pm
ladyada wrote:never heard of a motor frying the bootloader so im wondering whats up. regardless you can burn your own bootloader if you have a chip programmer or i have them in the adafruit.com shop
I have ordered a new ATMega. They are already burned with a bootloader, right? I thought that this might be a less expensive solution. Do you think that this will work?
richile
by adafruit on Wed May 07, 2008 9:25 pm
it depends on where you ordered the atmega from
by richile on Thu May 08, 2008 11:10 am
Adafruit
richile
