servo_2 problem
servo_2 problem
by gekko on Thu May 08, 2008 9:52 am
I recently bought the motor shield from adafruit and two servos from another site. I have soldered the shield together and hooked everything up correctly i believe.
The SER1 line runs almost perfectly(smooth and accurately) however my SERVO_2 line does not ( many "jitters" and seldomly accurate).
I have swapped the servos a few times and can confirm it is not a problem with the servo itself. The servos are Hitec HS-332HD's. I have been using usb power for the arduino and the dc adapter for the motor board. I have also been using the sample servo code supplied on the motor shield tutorial page on ladyada.net .
thanks in advance for any help!
gekko
by adafruit on Thu May 08, 2008 12:27 pm
what happens when you swap the servos
what happens if you only run servo 2
by gekko on Thu May 22, 2008 10:01 pm
ty for the help!
I'm not really sure what I did or what happend but it seems to be working now. If i had to guess i would say it was a short between the motor board and another board that I was stacking it with or a power problem.
gekko
