Motor Shield doesn't seem to be working
by etharooni on Sat May 10, 2008 6:36 pm
Yeah, Hi. I just got my motor shield at Maker Faire the other day and soldered it just recently. When I plug it in, the LED doesn't come on. Should it? I tried both the DC motor and Stepper motor programs which didn't work. What's the problem?
etharooni
by adafruit on Sat May 10, 2008 11:42 pm
you should post a clear, non-blurry, high quality, in focus photo of your assembled shield
by etharooni on Sun May 11, 2008 1:50 am
ladyada wrote:you should post a clear, non-blurry, high quality, in focus photo of your assembled shield
k.
http://uploader.polorix.net//files/129/P5103615.JPG
http://uploader.polorix.net//files/129/P5103620.JPG
http://uploader.polorix.net//files/129/P5103621.JPG
It's my first successful PCB soldering attempt. As you can probably tell by the soldering, I'm a n00b.
etharooni
by adafruit on Sun May 11, 2008 11:47 pm
the soldering is mostly good, but there are many sketchy-looking joints
go thru and resolder the points
also make sure you're providing 9V power to the arduino thru the DC plug
by etharooni on Mon May 12, 2008 10:58 pm
ladyada wrote:the soldering is mostly good, but there are many sketchy-looking joints
Ok, now the LED turns on, but the motors still don't do anything. Thanks for the help so far though!
etharooni
by etharooni on Mon May 12, 2008 11:33 pm
yes! it worked all along! I just didn't realize that if the jumper was set to USB and the Power Jumper was on, that both had to be in at the same time. It really is an awesome shield! But now I feel stupid!
etharooni
I killed my Arduino
by etharooni on Tue May 13, 2008 12:04 am
w00t Triple Post!
I was playing around with stepper scripts and boom:
avrdude: verification error, first mismatch at byte 0x0002
         0x5a != 0x37
avrdude: verification error; content mismatch
It shows up on any script I try uploading.
YAY! I killed it! Should I order a new atmega168 or is it something I can fix?
etharooni
by adafruit on Tue May 13, 2008 10:19 am
id try to upload again, perhaps removing the shield. it could be that you borked the chip :(
by etharooni on Tue May 13, 2008 10:53 pm
ladyada wrote:id try to upload again, perhaps removing the shield. it could be that you borked the chip :(
Yeah. I tried that. I think I killed it. I'm gonna bye another chip, so yeah.
EDIT: Heh heh. I spelled it Bye.
etharooni
