Strange motor behavior
by Tex Funk on Thu May 15, 2008 9:10 pm
I'm trying to get the sample code for DC motors working with my motors, but I'm getting some strange behavior; regardless of what I do, the motor starts turning in one direction and keeps going that way. It also doesn't seem to work at speeds lower than 230 or so. I suspect this has to do with the cheap motors I got; anybody have any ideas?
The code I'm using currently:
#include <AFMotor.h>
AF_DCMotor motor(2, MOTOR12_64KHZ); // create motor #2, 64KHz pwm
  Serial.begin(9600);           // set up Serial library at 9600 bps
  Serial.println("Motor test!");
  motor.setSpeed(230);     // set the speed to 200/255
  Serial.print("tick");
  motor.run(FORWARD);      // turn it on going forward
  delay(1000);
    Serial.print("tack");
  motor.run(RELEASE);      // stopped
  delay(1000);
  Serial.print("tock");
  motor.run(BACKWARD);     // the other way
  delay(1000);
Checking the voltage on the motor outs it does seem to be staying consistent.
Tex Funk
by Tex Funk on Thu May 15, 2008 9:42 pm
Well, it started working. Any thoughts why that might be?
Tex Funk
by Tex Funk on Fri May 16, 2008 10:28 am
And, somewhat later, it completely stopped working. The input voltage seems fine, I'm just not getting any output. This came shortly after I commented the releases out, and I'm using the off-brand H-bridge (the SN754410). I'm running two motors off a single AC adaptor, but it's possible it's a relatively high amperage AC adaptor: could I have blown the h-bridge chip up? I had the motors on M1 and M2.
Tex Funk
by Tex Funk on Sat May 17, 2008 11:52 am
To answer my own questions: it wasn't working because of a short on the proto shield I was stacking on top of it; I took that off and it worked fine. Also, the H-Bridge chip definitely wasn't blown, because if that had happened, I would have seen it, smelled it, and it would have looked like this:
Oops.
Tex Funk
by adafruit on Sun May 18, 2008 12:58 pm
yes that is most certainly what a blown chip will look like! :P
by Jokerman on Thu May 22, 2008 6:10 pm
The driver IC looks foobar - its definitely let its silicon goodness free :-)
-=mike=-
Jokerman
