Re: MODBUS TCP via WiFi Shield
by rody2571 on Tue Sep 01, 2015 3:35 pm
Hi abba,
I tested your library with my ESP8266 but when I'm compiling the program I get some fails.
Arduino:1.6.5 (Windows 8.1), Placa:"Generic ESP8266 Module, Serial, 80 MHz, 40MHz, DIO, 115200, 4M (3M SPIFFS)"
In file included from C:\Program Files (x86)\Arduino\libraries\WiFi\src\WiFiUdp.cpp:29:0:
C:\Program Files (x86)\Arduino\libraries\WiFi\src\WiFiUdp.h:25:0: warning: "UDP_TX_PACKET_MAX_SIZE" redefined [enabled by default]
#define UDP_TX_PACKET_MAX_SIZE 24
In file included from C:\Program Files (x86)\Arduino\libraries\WiFi\src\utility/wifi_drv.h:26:0,
from C:\Program Files (x86)\Arduino\libraries\WiFi\src\WiFiUdp.cpp:26:
C:\Users\SMART-PC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\libraries\ESP8266WiFi\src/WiFiUdp.h:28:0: note: this is the location of the previous definition
#define UDP_TX_PACKET_MAX_SIZE 8192
C:\Program Files (x86)\Arduino\libraries\WiFi\src\WiFiUdp.h:27:7: error: redefinition of 'class WiFiUDP'
class WiFiUDP : public UDP {
C:\Users\SMART-PC\AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-947-g39819f0\libraries\ESP8266WiFi\src/WiFiUdp.h:32:7: error: previous definition of 'class WiFiUDP'
class WiFiUDP : public UDP, public SList<WiFiUDP> {
C:\Program Files (x86)\Arduino\libraries\WiFi\src\WiFiUdp.cpp: In constructor 'WiFiUDP::WiFiUDP()':
C:\Program Files (x86)\Arduino\libraries\WiFi\src\WiFiUdp.cpp:35:22: error: class 'WiFiUDP' does not have any field named '_sock'
WiFiUDP::WiFiUDP() : _sock(NO_SOCKET_AVAIL) {}
C:\Program Files (x86)\Arduino\libraries\WiFi\src\WiFiUdp.cpp: In member function 'virtual uint8_t WiFiUDP::begin(uint16_t)':
C:\Program Files (x86)\Arduino\libraries\WiFi\src\WiFiUdp.cpp:45:9: error: '_sock' was not declared in this scope
_sock = sock;
C:\Program Files (x86)\Arduino\libraries\WiFi\src\WiFiUdp.cpp:46:9: error: '_port' was not declared in this scope
_port = port;
C:\Program Files (x86)\Arduino\libraries\WiFi\src\WiFiUdp.cpp: In member function 'virtual int WiFiUDP::available()':
C:\Program Files (x86)\Arduino\libraries\WiFi\src\WiFiUdp.cpp:56:7: error: '_sock' was not declared in this scope
if (_sock != NO_SOCKET_AVAIL)
C:\Program Files (x86)\Arduino\libraries\WiFi\src\WiFiUdp.cpp: In member function 'virtual void WiFiUDP::stop()':
C:\Program Files (x86)\Arduino\libraries\WiFi\src\WiFiUdp.cpp:66:8: error: '_sock' was not declared in this scope
if (_sock == NO_SOCKET_AVAIL)
C:\Program Files (x86)\Arduino\libraries\WiFi\src\WiFiUdp.cpp:69:26: error: '_sock' was not declared in this scope
ServerDrv::stopClient(_sock);
C:\Program Files (x86)\Arduino\libraries\WiFi\src\WiFiUdp.cpp: In member function 'virtual int WiFiUDP::beginPacket(IPAddress, uint16_t)':
C:\Program Files (x86)\Arduino\libraries\WiFi\src\WiFiUdp.cpp:88:7: error: '_sock' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\WiFi\src\WiFiUdp.cpp:90:7: error: '_sock' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\WiFi\src\WiFiUdp.cpp: In member function 'virtual int WiFiUDP::endPacket()':
C:\Program Files (x86)\Arduino\libraries\WiFi\src\WiFiUdp.cpp:101:32: error: '_sock' was not declared in this scope
return ServerDrv::sendUdpData(_sock);
C:\Program Files (x86)\Arduino\libraries\WiFi\src\WiFiUdp.cpp: In member function 'virtual size_t WiFiUDP::write(const uint8_t*, size_t)':
C:\Program Files (x86)\Arduino\libraries\WiFi\src\WiFiUdp.cpp:111:27: error: '_sock' was not declared in this scope
ServerDrv::insertDataBuf(_sock, buffer, size);
C:\Program Files (x86)\Arduino\libraries\WiFi\src\WiFiUdp.cpp: In member function 'virtual int WiFiUDP::read()':
C:\Program Files (x86)\Arduino\libraries\WiFi\src\WiFiUdp.cpp:125:23: error: '_sock' was not declared in this scope
ServerDrv::getData(_sock, &b);
C:\Program Files (x86)\Arduino\libraries\WiFi\src\WiFiUdp.cpp: In member function 'virtual int WiFiUDP::read(unsigned char*, size_t)':
C:\Program Files (x86)\Arduino\libraries\WiFi\src\WiFiUdp.cpp:137:31: error: '_sock' was not declared in this scope
if (!ServerDrv::getDataBuf(_sock, buffer, &size))
C:\Program Files (x86)\Arduino\libraries\WiFi\src\WiFiUdp.cpp: In member function 'virtual int WiFiUDP::peek()':
C:\Program Files (x86)\Arduino\libraries\WiFi\src\WiFiUdp.cpp:152:22: error: '_sock' was not declared in this scope
ServerDrv::getData(_sock, &b, 1);
C:\Program Files (x86)\Arduino\libraries\WiFi\src\WiFiUdp.cpp: In member function 'virtual IPAddress WiFiUDP::remoteIP()':
C:\Program Files (x86)\Arduino\libraries\WiFi\src\WiFiUdp.cpp:167:25: error: '_sock' was not declared in this scope
WiFiDrv::getRemoteData(_sock, _remoteIp, _remotePort);
C:\Program Files (x86)\Arduino\libraries\WiFi\src\WiFiUdp.cpp: In member function 'virtual uint16_t WiFiUDP::remotePort()':
C:\Program Files (x86)\Arduino\libraries\WiFi\src\WiFiUdp.cpp:177:25: error: '_sock' was not declared in this scope
Error de compilación
activala desde Archivo > Preferencias
