VU meter with Music Maker shield
by alecwaters on Mon Oct 20, 2014 5:56 pm
I've seen other projects where a VU meter has been made by calling analogRead() on a pin attached to an audio source (like a 3.5mm jack, or indirectly via an amplified electret mic).
Is there somewhere on the Music Maker I can tap to achieve the same thing? The line out socket somehow?
Many thanks,
alec
PS - the "resistor" captcha on this forum is tricky when one is colour blind :)
alecwaters
Re: VU meter with Music Maker shield
by adafruit_support_mike on Tue Oct 21, 2014 2:18 am
If you have the version without a class-D amplifier to drive speakers, you can pull the left, right, and GND signals from the pads that would provide input to the amp:
Otherwise, you'd have to take the signal that comes out of the headphone jack.
by alecwaters on Tue Oct 21, 2014 6:14 am
Thanks Mike.
I've got the amplified version, so I'll have to take it from the headphone jack.
Is it safe to go straight from the L and R connections to analog pins? Or do I need to treat the signal somehow before it gets there?
Many thanks,
alec
alecwaters
by adafruit_support_mike on Thu Oct 23, 2014 9:58 pm
The headphone outputs are decoupled through 220 microfarad capacitors, which leaves the signals 'floating'.. independent of the Arduino's VCC and GND rails. You need a current path to a known voltage to guarantee the signals stay in a range where you can measure them.
Make a couple of 10k-10k voltage dividers between VCC and GND, and connect each output to the center of a divider. That will give you an AC signal centered at 2.5v.
by alecwaters on Thu Oct 30, 2014 7:56 am
Thanks Mike.
In the end I used a Sparkfun Spectrum Shield (I know, a competitor's product!)
The end result is this (the spectrum shield kicks in at about 40s):
http://youtu.be/0xwMbbmw55Y
alecwaters
by adafruit_support_mike on Thu Oct 30, 2014 2:23 pm
Whoa.. *nice* build!
Since I know everyone who sees the video will ask, could you give a quick explanation of how you covered the LEDs to make them invisible when they're off?
BTW - the folks from Sparkfun are our friends. Any 'competition' between us and them is on the order of "who's going to get that next star in Mario Kart?"
by alecwaters on Thu Oct 30, 2014 5:11 pm
Hi Mike,
Thankyou :)
The gravestone is just paper stuck to card, and the Arduino etc is in an enclosure fixed behind it. The card has a cut-out in the middle that goes around the enclosure like a lion's mane. This means that there's only paper over the front of the enclosure where the LEDs are mounted - they just shine through the paper when they're on!
alec
alecwaters
by adafruit_support_mike on Fri Oct 31, 2014 3:28 pm
I like it.. simple, elegant, and easy to customize.
Once again, kudos for an excellent build.
cron
