I thought I'd build my girlfriend a device that will indicate current weather conditions; she asks me too often! My plan is to use the ethernet shield to find weather data, then display the data by having a servo point to a weather condition icon. This is similar to Tom Igoe's air quality meter project. However, his book seems to skip over the basics, which is what I need help with. How do I get the ball rolling??
using ethernet shield to return weather data
- Franklin97355
That's a very open ended question with little substance to work with. I would get the arduino and the ethernet shield, don't forget to get an xport. Put it all together and play with it a while doing the tutorials and examples. When you run up against something you don't understand ask questions here. Hope this is enough to get you started.
I have an arduino and the ethernet shield, and I have done some of the examples. I'll check out the twitter stuff, but I was originally thinking of using weather.com or something similar to parse the weather data. I guess my main problem is my inability to write code at this point. Thanks for the pointers! If you have any other suggestions, let me know. I'm open to anything.
Tom
Tom
