Wav shield card init.failed
by sfta on Fri Aug 15, 2008 1:11 pm
After getting this error, I read all other posts on this topic, and was wondering if there is a reliable way to get things working. There are a few different approaches offered in the forum:
Check all the joints on the board
Formatting the card on a mac, then reformat on a pc
Update the library
Try a card thats under 1gb or until you find one that works
I've tried the first three and would like to avoid the last option. The trick seems to be in the formating. Can someone post how the managed to do it?
the details:
sd card: Panasonic 1gb class2
Arduino NG 168
wave with the NG hacks
SFTA
sfta
by adafruit on Fri Aug 15, 2008 3:58 pm
class 2 (SDHC?) wont work
by sfta on Fri Aug 15, 2008 4:18 pm
Not sure if its SDHC but def class2.
What type of cards will work? Is there documentation that I missed.
Dang. That might explain my troubles...
SFTA
sfta
by adafruit on Sat Aug 16, 2008 4:22 pm
'standard issue' SD cards work fine. i now stock standard SD 1gig cards in the shop since people seem to have trouble finding them
by sfta on Mon Aug 18, 2008 7:59 pm
Tried new card (Kingston technology 1gb) still getting failure.
Triple checked board and all looks fine.
Checked card on mac and it is Fat16.
any ideas?
sfta
by adafruit on Tue Aug 19, 2008 7:22 pm
you can try posting a photo of your board
by sfta on Tue Aug 19, 2008 9:43 pm
I found a problem with my board, the C5 cap was in the wrong place. I removed and replaced it, but it didn't solve the card failure. Did I fry a chip?
Anyway, here is a photo:
http://www.flickr.com/photos/8655707@N08/2779227255/
Thanks for the help.
SFTA
sfta
by adafruit on Thu Aug 28, 2008 5:00 pm
the kit hasnt been tested very well with an NG...id try a diecimila arduino (they're the current rev) after you replace the changed components
by westfw on Fri Aug 29, 2008 1:51 am
There have been rumors off on the JuiceBox forum (an ARM based video player that runs linux) that not all "SD" flash cards support the SPI/MMC mode that most simple devices like to use. IIRC, Kingston was one of the vendors that was supposed to be problematic... ( JuiceBox BBS post )
So before you get too paranoid about possible mistakes, you might want to try a different flash card.
(I don't think anyone ever explained WHY the kingston cards had problems; they're normally a pretty reputable memory vendor...)
westfw
Update
by sfta on Tue Sep 16, 2008 8:46 pm
Got my hands on a Diecimila, and shield is now working fine (after unhacking the NG hacks). So... upgrading an NG to an ATmega168 ain't enough--get a Diecimila and avoid some pain. The SD cards don't seem to be a problem after all.
SD cards that I have working:
Kingston 1GB
Dane-Elec 1GB
Panasonic Class 2 1GB
All were formatted on a PC running XP pro with a SanDisk ImageMate 5 in 1 reader.
Thanks to all who offered help and encouragement.
SFTA
sfta
