GPS shield problems
GPS shield problems
by thefatmoop on Tue Aug 19, 2008 4:47 pm
I went through the instructions on
http://ladyada.net/make/gpsshield/gpstest.html
put the the softserial 2 folders to
C:\arduino\arduino-0011\hardware\libraries
I also changed buffer to 32
I get this error when I check the programming from the example
java.lang.StackOverflowError
>< any ideas? here is screeny
thefatmoop
by adafruit on Tue Aug 19, 2008 7:21 pm
use arduino v10
by thefatmoop on Wed Aug 20, 2008 12:39 pm
thanks
thefatmoop
by thefatmoop on Fri Aug 22, 2008 11:09 pm
Problemo numbero 2o
Okies so i got my gps+shield in the mail. I tested the GPS using the serial cable normally used to program the boarduino w/e... Everything worked, and the gps had a lock VERY quickly compared to my car gps...
i'm just trying out the logging features. I downloaded all the libraries, changed the buffer to 32.
i've tried both example codes from
http://www.ladyada.net/make/gpsshield/download.html
Neither one will light up L1 or L2, It doesn't log to the SD card.
GPSlogger
writing to GPSLOG00.TXT
ready!
$PSRF151,1*3F
$PSRF103,4,0,1,1*21
$PSRF103,3,0,0,1*27
$PSRF103,2,0,0,1*26
$PSRF103,0,0,0,1*24
It never goes to GPSLOG01.TXT or 02 03...
Tried 3 different SD cards made from different companies 2x 256 and 1x 1gig all formated in "FAT"(16) and i even did the "safely remove..." cause linux doesn't do the buffer.. arduino prob doesn't
thefatmoop
by thefatmoop on Fri Aug 22, 2008 11:36 pm
nvm lol jeez i never moved over the gps pins to share same slots as the serial... hope i didn't damage anything >< lady lady may get more of my $$ =P
thefatmoop
by thefatmoop on Sat Aug 23, 2008 12:55 am
it works ^^ now i need to make something kiwi kewl
thefatmoop
