SPI Library
SPI Library
by fabriziosilvetti on Mon Feb 23, 2015 7:41 am
Good morning, I purchase some Music Maker "MP3 Shield", but I have problems programming Arduino UNO for their use.
I'm using Arduino UNO + Adafruit Music Maker "MP3 Shield" with Arduino 1.6.0 IDE.
Charging the Adafruit Example Sketch the compiler return me this error message:
C:\Program Files (x86)\Arduino\libraries\SD\src\utility\Sd2Card.cpp:27:8: error: 'SPISettings' does not name a type
static SPISettings settings;
C:\Program Files (x86)\Arduino\libraries\SD\src\utility\Sd2Card.cpp: In member function 'void Sd2Card::chipSelectHigh()':
C:\Program Files (x86)\Arduino\libraries\SD\src\utility\Sd2Card.cpp:167:9: error: 'class SPIClass' has no member named 'endTransaction'
SPI.endTransaction();
C:\Program Files (x86)\Arduino\libraries\SD\src\utility\Sd2Card.cpp: In member function 'void Sd2Card::chipSelectLow()':
C:\Program Files (x86)\Arduino\libraries\SD\src\utility\Sd2Card.cpp:176:9: error: 'class SPIClass' has no member named 'beginTransaction'
SPI.beginTransaction(settings);
C:\Program Files (x86)\Arduino\libraries\SD\src\utility\Sd2Card.cpp:176:26: error: 'settings' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\SD\src\utility\Sd2Card.cpp: In member function 'uint8_t Sd2Card::init(uint8_t, uint8_t)':
C:\Program Files (x86)\Arduino\libraries\SD\src\utility\Sd2Card.cpp:269:3: error: 'settings' was not declared in this scope
settings = SPISettings(250000, MSBFIRST, SPI_MODE0);
C:\Program Files (x86)\Arduino\libraries\SD\src\utility\Sd2Card.cpp:269:53: error: 'SPISettings' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\SD\src\utility\Sd2Card.cpp:275:7: error: 'class SPIClass' has no member named 'beginTransaction'
C:\Program Files (x86)\Arduino\libraries\SD\src\utility\Sd2Card.cpp:279:7: error: 'class SPIClass' has no member named 'endTransaction'
C:\Program Files (x86)\Arduino\libraries\SD\src\utility\Sd2Card.cpp: In member function 'uint8_t Sd2Card::setSckRate(uint8_t)':
C:\Program Files (x86)\Arduino\libraries\SD\src\utility\Sd2Card.cpp:518:14: error: 'settings' was not declared in this scope
case 0: settings = SPISettings(25000000, MSBFIRST, SPI_MODE0); break;
C:\Program Files (x86)\Arduino\libraries\SD\src\utility\Sd2Card.cpp:518:66: error: 'SPISettings' was not declared in this scope
Errore durante la compilazione
the sketch is:
  This is an example for the Adafruit VS1053 Codec Breakout
  Designed specifically to work with the Adafruit VS1053 Codec Breakout
  ----> https://www.adafruit.com/products/1381
  products from Adafruit!
// include SPI, MP3 and SD libraries
#include <SPI.h>
#include <Adafruit_VS1053.h>
#include <SD.h>
// define the pins used
//#define CLK 13       // SPI Clock, shared with SD card
//#define MISO 12      // Input data, from VS1053/SD card
//#define MOSI 11      // Output data, to VS1053/SD card
// Connect CLK, MISO and MOSI to hardware SPI pins.
// See http://arduino.cc/en/Reference/SPI "Connections"
// These are the pins used for the breakout example
#define BREAKOUT_RESET  9      // VS1053 reset pin (output)
#define BREAKOUT_CS     10     // VS1053 chip select pin (output)
#define BREAKOUT_DCS    8      // VS1053 Data/command select pin (output)
// These are the pins used for the music maker shield
#define SHIELD_RESET  -1      // VS1053 reset pin (unused!)
#define SHIELD_CS     7      // VS1053 chip select pin (output)
#define SHIELD_DCS    6      // VS1053 Data/command select pin (output)
// These are common pins between breakout and shield
#define CARDCS 4     // Card chip select pin
// DREQ should be an Int pin, see http://arduino.cc/en/Reference/attachInterrupt
#define DREQ 3       // VS1053 Data request, ideally an Interrupt pin
Adafruit_VS1053_FilePlayer musicPlayer =
  // create breakout-example object!
  //Adafruit_VS1053_FilePlayer(BREAKOUT_RESET, BREAKOUT_CS, BREAKOUT_DCS, DREQ, CARDCS);
  // create shield-example object!
  Adafruit_VS1053_FilePlayer(SHIELD_RESET, SHIELD_CS, SHIELD_DCS, DREQ, CARDCS);
  Serial.begin(9600);
  Serial.println("Adafruit VS1053 Simple Test");
  if (! musicPlayer.begin()) { // initialise the music player
     Serial.println(F("Couldn't find VS1053, do you have the right pins defined?"));
     while (1);
  Serial.println(F("VS1053 found"));
  SD.begin(CARDCS);    // initialise the SD card
  // Set volume for left, right channels. lower numbers == louder volume!
  musicPlayer.setVolume(20,20);
  // Timer interrupts are not suggested, better to use DREQ interrupt!
  //musicPlayer.useInterrupt(VS1053_FILEPLAYER_TIMER0_INT); // timer int
  // If DREQ is on an interrupt pin (on uno, #2 or #3) we can do background
  // audio playing
  musicPlayer.useInterrupt(VS1053_FILEPLAYER_PIN_INT);  // DREQ int
  // Play one file, don't return until complete
  Serial.println(F("Playing track 001"));
  musicPlayer.playFullFile("track001.mp3");
  // Play another file in the background, REQUIRES interrupts!
  Serial.println(F("Playing track 002"));
  musicPlayer.startPlayingFile("track002.mp3");
  // File is playing in the background
  if (musicPlayer.stopped()) {
    Serial.println("Done playing music");
    while (1);
  if (Serial.available()) {
    char c = Serial.read();
    // if we get an 's' on the serial console, stop!
    if (c == 's') {
      musicPlayer.stopPlaying();
    // if we get an 'p' on the serial console, pause/unpause!
    if (c == 'p') {
      if (! musicPlayer.paused()) {
        Serial.println("Paused");
        musicPlayer.pausePlaying(true);
      } else {
        Serial.println("Resumed");
        musicPlayer.pausePlaying(false);
  delay(100);
Can I have your help???
Last edited by adafruit_support_bill on Mon Feb 23, 2015 8:25 am, edited 1 time in total.
Reason: Please use the '</>' button when posting code. Paste your code between the [code] tags.
fabriziosilvetti
Re: SPI Library
by adafruit_support_bill on Mon Feb 23, 2015 8:27 am
[Moved to the Arduino Shields forum]
This error means that the compiler was not able to find the library in the expected location. Please make sure that the library is installed according to these instructions: https://learn.adafruit.com/adafruit-all ... -libraries
Re: SPI Library
by fabriziosilvetti on Mon Feb 23, 2015 10:49 am
It's all right!!! Thanks
Problem solved..
fabriziosilvetti
Re: SPI Library
by 4711engel on Sun Jul 14, 2019 3:31 pm
Hallo,
ich habe folgendes Problem beim Kompilieren eines sketches.
Fehlermeldung:
In file included from InternetClock_ILI9341.ino:18:0:
C:\Users\uengel\Documents\Arduino\libraries\SPI/SPI.h:1378:8: error: 'SPIClass' does not name a type
extern SPIClass SPI;
In file included from InternetClock_ILI9341.ino:19:0:
C:\Users\uengel\Documents\Arduino\libraries\TFT_ILI9341_ESP/TFT_ILI9341_ESP.h:496:13: error: 'SPIClass' does not name a type
SPIClass *_SPI;
Ich verwende IDE 1.6.5 und den sketch aus dem Tutorial:
http://embedded-lab.com/blog/tutorial-8 ... nt-2458495
Da ich Anfänger bin, habe ich bis jetzt keine Erklärung für den SPI-Fehler.
Kannst Du helfen?
Danke
Ulli
InternetClock_ILI9341.zip
(770.78 KiB) Downloaded 16 times
4711engel
