is there some manual?
by cicciona on Mon Sep 01, 2008 1:00 pm
hello!
i need the manual about the function to drive the motor stepper or a more explanation, i didn't find nothing in the ladyada website ..only the exemple.
tanks
cicciona
by adafruit on Mon Sep 01, 2008 1:43 pm
there is not much to discuss with the motor shield, it is very straightforward
this is the manual
http://www.ladyada.net/make/mshield/use.html
by cicciona on Mon Sep 01, 2008 3:06 pm
i'm agree with you, it should be very simple but why the program works well with one motor and not with two? :shock:
cicciona
by grinan on Wed Sep 03, 2008 12:35 pm
I had issues at first running more that two motors. I can tell you from my experience that an inadequate power supply could be the problem.
Try giving the shield more power. And running the arduino off of a 9volt won't work very well. They just don't source enough power to keep things running right.
Almost every problem i have had with the motor shield has resulted from not enough power. I now have 2 rechargeable 9.6 volt nicd rc car batteries, and I keep one charging all the time... if i have a problem that doesn't make sense, i swap them out.
grinan
