Black Lives Matter - Action and Equality. ... Adafruit is part of the Stop Hate for Profit campaign. Adafruit is open and shipping.
Boosting the power of the Motor shield
by shobley on Tue Sep 02, 2008 11:34 pm
Is it a viable option to route the output of the motor shield through some big mosfets or other high power switching transistors?
I'd like to handle a lot more amps and control a fairly heavy device.
Is this a straightforward procedure - or is it tricky?
Steve
shobley
by adafruit on Wed Sep 03, 2008 12:27 am
if you need more than double, you are better off building a motor driver with different chips that are intended to power large motor
by shobley on Wed Sep 03, 2008 11:30 am
Is the output from the stepper library something that could be hooked up to this board?
http://www.kitsrus.com/pdf/k179.pdf
It looks like 3 wires, direction, gnd and step.
shobley
by adafruit on Wed Sep 03, 2008 11:57 am
the library is specially designed for the shield and is unlikely to work with anything else
by shobley on Wed Sep 03, 2008 2:07 pm
Darn!
But servo still works without the shield right?
That looks like GND, 5V and pin 9 (and 10).
I could probably rustle something up to run the K179...
Steve
shobley
by adafruit on Wed Sep 03, 2008 4:11 pm
yes
