Boosting the power of the Motor shield
by shobley on Tue Sep 02, 2008 11:34 pm
Is it a viable option to route the output of the motor shield through some big mosfets or other high power switching transistors?
I'd like to handle a lot more amps and control a fairly heavy device.
Is this a straightforward procedure - or is it tricky?
Steve
shobley
by adafruit on Wed Sep 03, 2008 12:27 am
if you need more than double, you are better off building a motor driver with different chips that are intended to power large motor
by shobley on Wed Sep 03, 2008 11:30 am
Is the output from the stepper library something that could be hooked up to this board?
http://www.kitsrus.com/pdf/k179.pdf
It looks like 3 wires, direction, gnd and step.
shobley
by adafruit on Wed Sep 03, 2008 11:57 am
the library is specially designed for the shield and is unlikely to work with anything else
by shobley on Wed Sep 03, 2008 2:07 pm
Darn!
But servo still works without the shield right?
That looks like GND, 5V and pin 9 (and 10).
I could probably rustle something up to run the K179...
Steve
shobley
by adafruit on Wed Sep 03, 2008 4:11 pm
yes
