Analog write to PWM pin 9 stops waveshield working
by rasterblaster on Wed Sep 10, 2008 4:29 am
I have a little program running on my waveshiled, that plays sound and also needs to move two analoge panel meters.
In testing it out, it works fine if I use PWM pin 6.
When I use PWM pin 9, the waveshiled stops working.
(all I have done is changed the code to say pin 9 instead of pin 6, not even trying to do them both at once at this stage)
At first I thought perhaps waveshield uses pin 9, but all the documentation says that it does not.
I then suspected that is my arduino board, so I put in a simple hello world program that only sends a value to PWM pin 9 (or pin 6) and that works.
I then suspected that perhaps there is a short on the waveshield board? so I ran my hello world program with the waveshield plugged on. hello world works on pin 9 and 6.
The only thing I can think of is that there is something in the librarys for the waveshield that use pin 9 (even though the documentation says that nothing does)
Help!
any ideas? :?
if you like science fiction art and sci-fi sculpture, have a look at my website www.marty.com.au
rasterblaster
by adafruit on Wed Sep 10, 2008 10:32 am
it doesnt use pin 9 directly
but it does use the interrupt that would drive pin 9 PWM engine as part of the audio decoding stuff
by rasterblaster on Wed Sep 10, 2008 8:33 pm
ladyada wrote:it doesnt use pin 9 directly
Hmm.. so what does that exactly mean? I can use pin 9 for "on" "off" type stuff, but not PWM.
the pin 5 and 3 that the audio shield uses that are also PWM capable, do they have to be PWM pins, can I move one of them to another pin?
Is there any other way around this?
rasterblaster
by adafruit on Wed Sep 10, 2008 10:08 pm
yup. just on/off
i dont think any other timers are used, so you can use a 'software' servo or a different PWM
by rasterblaster on Wed Sep 10, 2008 10:34 pm
ladyada wrote:yup. just on/off
Ok, so if I was to chage the waveshield librarys from using say pin 3 to pin 9, to free up pin three PWM, what would I have to change in the library? (as well as obviously changing the physical wire jumper from pin 3 to 9 on the waveshiled board...
and what do you mean by a "software servo"
thanks for your help so far by the way.
rasterblaster
by adafruit on Thu Sep 11, 2008 12:14 am
i dont have a tutorial for what to change in the library to free up the pins
http://www.google.com/search?q=arduino+software+servo
