Problem with Raspi2, Arduberry and Servo Shield
sisomm
Post by sisomm »
I am upgrading this project to Raspberry 2.: https://utbrudd.bouvet.no/2014/03/10/an ... -and-mqtt/. I can't get the arduberry to behave well with the servo shield.. I have started a support issue with Dexter Industries, but they are noen the wiser. Can you have a look at this support thread? http://www.dexterindustries.com/topic/p ... post-77542
Re: Problem with Raspi2, Arduberry and Servo Shield
Not familiar with the Arduberry. All communication with the shield is via the i2c bus. By default, the shied pulls the bus up to 5v. This might be a problem for any 3.3v devices on the bus. There is a "VCC Select" jumper that allows you to switch the shield to use 3.3v logic.
sisomm
Post by sisomm »
SOLVED! It's a conflict with the SCL and SDA pins used to communicate with the official PI screen.
See how to connect the screen here: http://thepihut.com/blogs/raspberry-pi- ... mbly-guide
Once I removed them, it worked like a charm. Now, what to do... I want to combine Arduberrry/Adafruit with a Pi2 and display...
Good to hear! Thanks for the follow-up.
sisomm
Post by sisomm »
Could I change the I2C address of the servo shield and hence avoid the conflict?
If it is an address conflict, you can easily re-address the board: https://learn.adafruit.com/adafruit-16- ... he-shields
sisomm
Post by sisomm »
this solved it! (From CleoQc @ the Dexter forum)
Just jumping in here, maybe the following will be useful?
Found on the Raspberripi.org forums:
https://www.raspberrypi.org/forums/view ... 8&t=120681
If you have a B+, a Pi2 or an A+ you need not connect the i2c GPIO wires as they are taken care of in the DSI ribbon connector.
I just received the official screen, but I haven’t opened the box yet. And I don’t own an Arduberry. So I’m not speaking from experience.
sisomm
Post by sisomm »
Here's a video of the end result: A plastic skull, Makeblock, etc. It can be used as a showcase for the local code clubs. https://www.youtube.com/watch?v=o23ZX6JZyZY
Great! Thanks for the video.
