I'm building a data logger using Arduino and Adafruit's Micro SD breakout board.
The program uses the Arduino core SD library.
So, the thing is: the Arduino should log the data once a minute to a file. So far, there's no problem.
But once a hour, the Arduino should create a backup of the logfile. The program should copy the file from the root of the SD to the backup-folder.
I didnt find a function to copy files on the SD card.
How can I do this?
SD Shield: Copy/Rename Files
Re: SD Shield: Copy/Rename Files
There is no copy function.
You'll have to open two files, read the old one, and write the same information to the new one.
- pierrot10
Would it be a good idea to add the rename/move function to be able to rename a file?
I think it could be a very good option.
Cheers
Cheers
It isn't our library.
