Uzebox Kit not working properly
Moderator: adafruit
by chrissiak on Wed Aug 26, 2015 4:34 pm
I recently purchased the Uzebox kit available on your shop, and after putting it all together, it is not working 100% correct. It loads the AVR Megatris game but when I attempt to exit to the bootloader by holding in a button on the controller and pressing the reset button, the bootloader fails to recognize that the SD card is inserted. It says that there is no SD card inserted when there is. Also, the Power button does nothing. I can only power on the Uzebox by plugging it in, and power it off by unplugging it. If anyone knows what could be my problem, I'd appreciate any help or advice! I thought I did a pretty decent soldering job, images are below.
Chris
chrissiak
Re: Uzebox Kit not working properly
by adafruit2 on Mon Sep 07, 2015 10:57 pm
just to check, can you load any games from the SD card or none at all - and can you play the games themselves?
adafruit2
Site Admin
by chrissiak on Mon Sep 07, 2015 11:26 pm
I can't load any games from the SD card. The only playable game is Tetris because it was already flashed on the microcontroller and is not being read off the SD card. But the Tetris is fully playable.
chrissiak
by adafruit2 on Mon Sep 07, 2015 11:34 pm
its almost certainly the soldering on the SD card holder then - make sure there's no shorts/bridging/cold solder joints. your solder points look ok for THM but i think your iron isnt hot enough/fine enough?
adafruit2
Site Admin
by chrissiak on Mon Sep 07, 2015 11:51 pm
Thanks, I will work on it with a finer soldering iron and report back. Does this have anything to do with the power switch or is that a different issue?
chrissiak
by adafruit2 on Tue Sep 08, 2015 12:34 am
*could* be related, but lets do the SD first - thats the easiest to debug :)
adafruit2
Site Admin
by CliffWold on Sat Apr 01, 2017 1:34 pm
Hi - I am having the same issue with my UZEBOX Starter Kits. I have just built 2 of these kits and they are both doing the same thing. The tetris works fine but as soon as I go to the bootloader, it is like it isn't recognizing the SD card that came with the kit. It knows a card is present but doesn't give me any directory / game listing. If I remove the card, it knows no card is there. Then I replace the card and it gives me a blank loading screen like the attached picture. I have tried different cards ( I had ordered 3 kits, thinking I would build them with my daughter's grade 7 class )
It looks like either the bootloader isn't working properly ( is the ATMEGA being shipped with the correct FW load? ) or the SD card is not recognized by the system. ( Did you change SD card suppliers recently? Mine came with Elite Pro HS 256MB SD Memory Cards ). Or is it something that I am doing incorrectly? The schematics that I see online don't seem to be a correct representation of this version of the board. ( V1.3.1 ) when I download them from the http://belogic.com/uzebox/downloads.htm
PS - I can see the games are present on the SD card when I insert it into my laptop SD card slot.
Can you please verify that the SD cards and bootloader combination that shipped to me is compatible and works together and what my next steps should be?
PS - My system is a Win 10 - 64 bit unfortunately for recompiling anything as it appears that any tutorials discussions only refer to older compilers.
Thanks very much for your assistance.
Cliff
Not worried about cold solder joints.. 2 boards did the same thing + not new to soldering.
Here is what I see.. Just bootloader rev 0.4.5 and it doesn't flash red like it should I think when loading. Nor do I have the option of load file or menu.
CliffWold
by adafruit2 on Sat Apr 01, 2017 7:01 pm
hiya plz contact uze, as they make the kit they're best at debugging setups! :) http://uzebox.org/forums/
adafruit2
Site Admin
by CliffWold on Tue Apr 04, 2017 7:45 pm
I actually figured it out myself. It is the SD card is not compatible with the boot loader. When I pulled a 1G card out of an older camera, formatted it and copied games across it worked fine.
CliffWold
