Compilation troubles
Moderator: adafruit
by Dan_K on Fri Dec 26, 2008 12:13 pm
Hi! First off, let me say thanks a lot for putting in the effort into creating and maintaining this project, it's been a lot of fun for me so far. However, I've run into a problem with compiling the Fuzebox's "Hello World" program, which I think is probably due to a misconfiguration on my part. I can get avrdude to talk to the Fuzebox perfectly fine, and I have been able to upload the sprites demo with no problems. Here's the output I get from the command prompt:
C:\Users\Dan>avrdude -p m644 -c stk500v1 -P COM6
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.05s
avrdude: Device signature = 0x1e9609
avrdude: safemode: Fuses OK
avrdude done.  Thank you.
C:\fuzefirmware-v2b2\hello>make
      0 [main] sh 4416 sync_with_child: child 4928(0x108) died before initializa
tion with status code 0x0
    708 [main] sh 4416 sync_with_child: *** child state waiting for longjmp
/usr/bin/sh: fork: Resource temporarily unavailable
avr-gcc.exe -I.. -mmcu=atmega644 -Wall -gdwarf-2 -std=gnu99 -DF_CPU=28636360UL -
Os -DVIDEO_MODE=1 -fsigned-char -MD -MP -MT hello.o -MF dep/hello.o.d  -c  hello
.c
hello.c:19: fatal error: opening dependency file dep/hello.o.d: No such file or
directory
compilation terminated.
make: *** [hello.o] Error 1
As you can see it communicates with the Fuzebox, but I'm getting problems trying to compile the example. Do you have any suggestions I can try? I'm running on Vista x64 if that helps.
Dan
EDIT: I guess attaching my Makefile will probably help too! The Device Manager lists the device as "USB Serial Port (COM6)", so using that information I've set the AVRDUDE_PORT variable to com6. I'm using the FTDI cable so AVRDUDE_PROGRAMMER is stk500v1. These are the only two variables I have changed.
# Makefile for the project Hello
## General Flags
PROJECT = hello
VIDEOMODE = 1
# Change if your programmer is different
AVRDUDE_PROGRAMMER = stk500v1
AVRDUDE_PORT = com6      # programmer connected to serial device
# Don't change unless you really know whats going on
MCU = atmega644
TARGET = $(PROJECT).elf
CC = avr-gcc.exe
## Options common to compile, link and assembly rules
COMMON = -mmcu=$(MCU)
## Compile options common for all C compilation units.
CFLAGS = $(COMMON)
CFLAGS += -Wall -gdwarf-2 -std=gnu99 -DF_CPU=28636360UL -Os -DVIDEO_MODE=$(VIDEOMODE) -fsigned-char
CFLAGS += -MD -MP -MT $(*F).o -MF dep/$(@F).d
## Assembly specific flags
ASMFLAGS = $(COMMON)
ASMFLAGS += $(CFLAGS)
ASMFLAGS += -x assembler-with-cpp -Wa,-gdwarf2
## Linker flags
LDFLAGS = $(COMMON)
LDFLAGS +=  -Wl,-Map=$(PROJECT).map
INCLUDES = -I..
## Intel Hex file production flags
HEX_FLASH_FLAGS = -R .eeprom
HEX_EEPROM_FLAGS = -j .eeprom
HEX_EEPROM_FLAGS += --set-section-flags=.eeprom="alloc,load"
HEX_EEPROM_FLAGS += --change-section-lma .eeprom=0 --no-change-warnings
## Objects that must be built in order to link
OBJECTS = $(PROJECT).o uzeboxCore.o uzeboxSoundEngine.o uzeboxSoundEngineCore.o uzeboxVideoEngine.o uzeboxVideoEngineCore.o
## Objects explicitly added by the user
LINKONLYOBJECTS =
AVRDUDE = avrdude
AVRDUDE_FLAGS = -p $(MCU) -P $(AVRDUDE_PORT) -c $(AVRDUDE_PROGRAMMER)
## Build
all: $(TARGET) $(PROJECT).hex $(PROJECT).eep $(PROJECT).lss size
# Program the device.
program: $(PROJECT).hex $(PROJECT).eep
   $(AVRDUDE) $(AVRDUDE_FLAGS) -B 1 -U flash:w:$<
## Compile
uzeboxSoundEngineCore.o: ../kernel/uzeboxSoundEngineCore.s
   $(CC) $(INCLUDES) $(ASMFLAGS) -c  $<
uzeboxVideoEngineCore.o: ../kernel/uzeboxVideoEngineCore.s
$(PROJECT).o: $(PROJECT).c
   $(CC) $(INCLUDES) $(CFLAGS) -c  $<
uzeboxCore.o: ../kernel/uzeboxCore.c
uzeboxSoundEngine.o: ../kernel/uzeboxSoundEngine.c
uzeboxVideoEngine.o: ../kernel/uzeboxVideoEngine.c
##Link
$(TARGET): $(OBJECTS)
    $(CC) $(LDFLAGS) $(INCFLAGS) $(OBJECTS) $(LINKONLYOBJECTS) $(LIBDIRS) $(LIBS) -o $(TARGET)
%.hex: $(TARGET)
   avr-objcopy -O ihex $(HEX_FLASH_FLAGS)  $< $@
%.eep: $(TARGET)
   -avr-objcopy $(HEX_EEPROM_FLAGS) -O ihex $< $@ || exit 0
%.lss: $(TARGET)
   avr-objdump -h -S $< > $@
   @echo
   @avr-size -C --mcu=${MCU} ${TARGET}
## Clean target
.PHONY: clean
clean:
   -rm -rf $(OBJECTS) $(PROJECT).elf dep/* $(PROJECT).hex $(PROJECT).eep $(PROJECT).lss $(PROJECT).map
## Other dependencies
-include $(shell mkdir dep 2>/dev/null) $(wildcard dep/*)
Dan_K
Re: Compilation troubles
by Dan_K on Fri Dec 26, 2008 1:16 pm
Aha! After much more digging around I've found the source of the problem. I'll paste my solution here for any other users experiencing the same problem:
It's a bug that appears in WinAVR on Vista x64, which causes the sync_with_child error that I was experiencing above. In order to solve it, you need to download a replacement msys-1.0.dll which goes in utils/bin/ on the WinAVR installation. The replacement dll file can be found here, which can be retrieved from this page.
Dan_K
by adafruit on Fri Dec 26, 2008 1:51 pm
yay vista!
by Dan_K on Fri Dec 26, 2008 3:16 pm
Hey, someone's got to be the guinea pig :P
I'm well on my way to making a Pong clone to get to grips with the kernel now. This is fun!
EDIT: Do you have an IRC channel by any chance?
Dan_K
by BrianC on Sun Dec 28, 2008 10:29 pm
ladyada wrote:yay vista!
Why do you assume it is Vista's fault, rather than the person that wrote the Cygwin DLL?
-Brian
We are all athiests; I just believe in one less god than you do. When you understand why you dismiss all the other possible gods, you will understand why I dismiss yours.
A refutation of Pascal's wager: http://www.geocities.com/paulntobin/pascal.html
BrianC
by adafruit on Sun Dec 28, 2008 11:13 pm
i didn't say it was vistas fault...this is a common occurrence when new OS's come out with non-backward-compatible apis. but he got it working which is good!
