Product Placement
Product Placement
by europasteve on Sat Feb 06, 2016 11:22 pm
You were on MythBusters! Zombie Ax
https://www.adafruit.com/products/2472
europasteve
Re: Product Placement
by adafruit_support_bill on Sun Feb 07, 2016 7:08 am
Cool! Thanks for posting that.
by jonRank on Tue Jul 12, 2016 3:29 pm
On my last order there two Raspberry Pi Cameras V2. One works great the other won't work. I get a "No data from sensor", erro. I've tried it on a known good Pi 3 that has a working camer as well as trying different cables on the camera.
order # 1140912
I like a replacement. Send me an RMA number and I'll ship the bad one back.
Thanks,
J. Rank
jrank@iland.net
jonRank
by xiaohong_hua on Tue Nov 08, 2016 10:41 pm
After receiving TFP401 HDMI/DVI Decoder to 40­Pin TTL Breakout ­ With Touch ,from view check found :
1: one board' inductor physical damaged ,refer to attach photo.
2: PCBA's connector &IC some PIN solder dry &less,refer to attach photo1.
3:insert flex cable to this Board’s connector hard difficult, if insert not properly case display peoblem. Refer to attach photo .
At view checking this board already failed, Based on the test result,we hope to replacement another board due to this board use for medical equipment need have good quality .if possible let we know can replace another Board for us?or give us technical support?
photo5-display unnormal.jpg (224.9 KiB) Viewed 1452 times
photo1-physcial damaged.jpg (498.49 KiB) Viewed 1452 times
xiaohong_hua
by dhongki on Fri Jan 26, 2018 5:27 pm
Is this thread still open? I just purchase a powerboost 500 that is overheating. the same component above causes the heat.
https://drive.google.com/open?id=15Zyxmn1UHG8y2PLbtns_sJRNmGEVrF2U
https://drive.google.com/open?id=1PdPmt8GpMqNQiz_RG2phFBy8Aek7q0tO
dhongki
by adafruit_support_bill on Fri Jan 26, 2018 5:55 pm
@dhongki
@xiaohong_hua
@ jonRank
Your posts are off-topic for this thread and this forum. Please post your question in an appropriate forum.
