Bluefruit exit from Beacon mode
by alpesh2559 on Fri Sep 25, 2015 12:52 am
hi..i use adafruit bluefruit LE (UART friend) with arduino protrinket board to control using android app to colour of neopixel using colour picker..i succefully work on app controller mode and able to change colour of neo pixel but one time i unfortunatly select beacon mode of app...so how to exit from becon mode of app...i uninstall app and reinstall so its still on beacon mode...i want to switch in controller mode....
alpesh2559
Re: Bluefruit exit from Beacon mode
by adafruit_support_mike on Fri Sep 25, 2015 2:52 am
You can reset the unit to its original condition by connecting the DFU pin to GND for more than 5 seconds:
https://learn.adafruit.com/introducing- ... ia-dfu-pin
by alpesh2559 on Fri Sep 25, 2015 6:05 am
but here issue in android app not in hardware undestand...app is run in becone mode continue if i uninstall and again reinstall than its open time continue show in becone mode
alpesh2559
by alpesh2559 on Fri Sep 25, 2015 6:06 am
i want to sitch over from becone mode to controller mode in android app...
alpesh2559
by adafruit_support_mike on Mon Sep 28, 2015 11:09 pm
You should be able to choose 'Disconnect' in the app, then reconnect. When you do, the app should give you a list of ways you can connect to the device.
