You were on MythBusters! Zombie Ax
https://www.adafruit.com/products/2472
Product Placement
- europasteve
Product Placement
Re: Product Placement
Cool! Thanks for posting that.
- jonRank
On my last order there two Raspberry Pi Cameras V2. One works great the other won't work. I get a "No data from sensor", erro. I've tried it on a known good Pi 3 that has a working camer as well as trying different cables on the camera.
order # 1140912
I like a replacement. Send me an RMA number and I'll ship the bad one back.
Thanks,
J. Rank
[email protected]
order # 1140912
Thanks,
J. Rank
[email protected]
- xiaohong_hua
After receiving TFP401 HDMI/DVI Decoder to 40Pin TTL Breakout With Touch ,from view check found :
1: one board' inductor physical damaged ,refer to attach photo.
2: PCBA's connector &IC some PIN solder dry &less,refer to attach photo1.
3:insert flex cable to this Board’s connector hard difficult, if insert not properly case display peoblem. Refer to attach photo .
At view checking this board already failed, Based on the test result,we hope to replacement another board due to this board use for medical equipment need have good quality .if possible let we know can replace another Board for us?or give us technical support?
- Attachments
- photo5-display unnormal.jpg (224.9 KiB) Viewed 5437 times
- photo1-physcial damaged.jpg (498.49 KiB) Viewed 5437 times
- dhongki
Is this thread still open? I just purchase a powerboost 500 that is overheating. the same component above causes the heat.
https://drive.google.com/open?id=15Zyxm ... RNmGEVrF2U
https://drive.google.com/open?id=1PdPmt ... y8Aek7q0tO
@dhongki
@xiaohong_hua
@ BANNED
Your posts are off-topic for this thread and this forum. Please post your question in an appropriate forum.
@xiaohong_hua
@ BANNED
