XBee Pro Module error number of red
by Adichip on Mon Aug 08, 2016 2:35 pm
Dear good afternoon , I have problems with one of the XBee ( 40c673df ) purchased from you
XBee Pro Module - ZB Series 2SC - 63MW with Wire Antenna - XBP24CZ7WIT - 004
I have to reset it to communicate and then set it .... Then to configure , do not take me the number of red.-
Please can you help me with this problem ?.
Thank you
Adichip
Re: XBee Pro Module error number of red
by adafruit_support_rick on Tue Aug 09, 2016 6:06 pm
Please post clear, detailed pictures of your soldering and wiring
by Adichip on Wed Aug 10, 2016 3:54 pm
First of all I thank you for your attention.
The assembly is next, I tried everything to make it work and I have no luck. Probe examples of the manufacturer's website but seems to have a problem with the module.
I would like to see if they can give me an example with the following:
1) Coordinator, which has enabled a digital output to refresh the input status of the Router.
2) Router, which has enabled a digital input.
With an example so you could try directly upload files to open with the X-CTU and this load on each Xbee.
To rule out serious the problem is the software.
Thank you very much in advance.
Best regards.
Adichip
by adafruit_support_rick on Thu Aug 11, 2016 11:51 am
You need a resistor on that LED. Otherwise, it is a direct short circuit to ground, which will damage the pin on the XBee.
Have you configured the XBees for pin-passing in X-CTU?
by Adichip on Fri Aug 12, 2016 9:13 am
Good morning, forgive my ignorance, I do not understand your question:
You have you any example that can be used to test the modules?
Thanks in advance.
Adichip
by adafruit_support_rick on Fri Aug 12, 2016 10:51 am
by Adichip on Tue Aug 16, 2016 10:19 am
Good morning Rick, first of all I appreciate the time you're engaging my problem. I wanted to let you know that the module that you have to buy the firmware version 802.14.11: 45 and so I could figure must be updated to version 802.15.4
Any help instructive to update to this latest version modules ?
I think my problem arises from this detail.
Thank you very much and good start to the week.
Best regards.
Adichip
Adichip
by adafruit_support_rick on Tue Aug 16, 2016 11:22 am
I think you're going to have to go to the Digi support forums. We don't know a lot about XBees here.
http://www.digi.com/support/forum/
