Adapter Issues
Adapter Issues
After assembling the Adafruit XBee adapter and powering up from an Arduino uno via breadboard (along with attaching Tx, Rx, and GND pins) - I haven't been able to get the lights to light up and don't have an FTDI cable to go about testing in that route. I checked the solder connections many times and they seem good and the power regulator on the adapter seems to warm up indicating its getting power, but I'm not sure what could be wrong. Any insight or troubleshooting info would be much appreciated. Thanks
- Franklin97355
Re: Adapter Issues
Usually the first thing asked for is large, clear pictures of both sides of the board. Seems to me there was an intermediate step where you tested the board to see if the power section was working, if so did it work? Also are you sure you have all the parts in the right way around?
Re: Adapter Issues
Yes. Photos of both sides of the board and one showing your connections to the Arduino also.Usually the first thing asked for is large, clear pictures of both sides of the board
Re: Adapter Issues
I am adding links for the photos I've taken, I tried reflowing some of the solder joints and tested the LED's they seem to be working fine, I dont have a capacitance tester to test these capacitors, but haven't done anything other than hook them up to the arduino. If there are any intermediate tests I would love to know how to perform them as well as any advice.
http://postimg.org/image/3rijmka25/ Back
http://postimg.org/image/mt8qwz5rh/ Front
http://postimg.org/image/3mvjtsp9p/ Connection w/ Arduino
Thanks for any help or tips. Much appreciated.
Re: Adapter Issues
There are quite a few joints where the solder has not wetted the pad. You need to heat the pad too so that the solder will flow well and create a good electrical bond. See this tutorial for tips on identifying and fixing those: http://learn.adafruit.com/adafruit-guid ... n-problems
Also, Did you check the voltage from the 3.3v voltage regulator to make sure that is working?
Re: Adapter Issues
Thank you - I am re-soldering/fixing what issues i can find now. What is the best way to check the regulator? I will re-post a photo in a few minutes when i finish soldering.
Re: Adapter Issues
When powered from your FTDI cable, you should measure 3.3v between the "GND" and "3V" pins.What is the best way to check the regulator?
Re: Adapter Issues
Here's post soldering - this closer image seems to make it easier to see - that guide you posted was helpful as well. I think they are all pretty good now. Unfortunately I am still waiting on the FTDI cable so I cannot test it that way -is there another method of testing you recommend? . Did my initial wiring to/from the Arduino look correct? I will be trying that shortly. Thank you.
http://postimg.org/image/xxljf36ct/
Re: Adapter Issues
Yes, your arduino connections look correct. What is the voltage between GND and 3V when powered from the Arduino 5v?
Re: Adapter Issues
Approximately 0.87 V is what I am reading, I assume this mean the regulator is not working properly? If so what should I do? Also - when the XBee is not connected both the green and red LED's light properly when tested with a multimeter. When the XBee is connected the green LED won't light and the red LED barely lights (very dimly). I am not quite sure if this is indicative of any particular problem.
Re: Adapter Issues
If you contact [email protected] with a link to this thread we can send a replacement voltage regulator.
Re: Adapter Issues
Thanks for the prompt support I will contact them now.
