Using XBee in dense urban areas
XBee projects like the adapter, xBee tutorials, tweetawatt/wattcher, etc. from Adafruit
CaseyScalf
Post by CaseyScalf »
I am looking to use the XBee for wireless communication between art projects at a large music festival. I just need to send the values of a few faders and buttons. I have notoriously had trouble using my iPad to connect with my Mac over an "ad-hoc network" just a few feet away because of the extremely dense networks and communications taking place - both wifi and cellular.
I want to know if this product may be vulnerable to the same woes? I read it usually uses a 2.4Ghz frequency (which is the same my ad-hoc wifi used) so I am worried it will be troubled just the same.
I only need to transmit 1 city block. So it sounds like I may need the pro version. I just need to know if it will suffer interference.
Thanks for any insight! I am open to other ideas for transmission if this looks like it won't work.
Franklin97355
Re: Using XBee in dense urban areas
Post by Franklin97355 »
Digi has 900 mhz solutions you might consider as an alternative.
CaseyScalf
I have seen those. But 900 is also a frequency used by cell phones so I'd like to avoid that section of the spectrum is possible.
Are there any other frequencies available?
Franklin97355
If you want to use xbee's check the Digi site for more info on devices and their capabilities. http://www.digi.com
CaseyScalf
I was hoping since you sell them and I was going to buy them from you that you might provide a little more assistance?
Franklin97355
Since your requirements for use are so far out of the norm we have no experience with that type of use. That is why I recommended Digi. If you have questions about the hardware and how to use it we may be of help.
CaseyScalf
Okay thanks, I'll try around.
Return to “XBee products (discontinued)”
