XBee Progrmer Com loss
by rareed13 on Sun Feb 07, 2016 6:21 pm
New user here. I have two XBees one I have configured to be a Coordinator AT the other an End device AT. The Coordinator works great. The problem is with the End device. When I try to connect to the End node the programmer will fail seconds after the XBee is powered. For example, I connect USB to the computer and run Test/Query. It comes back with the expected informant for modem ok. If I wait 5 or so seconds and run the test again it failed and ask to reset the XBee. I need a starting point to troubleshoot this issue.
I have tried a different programmer with the same issue. I have also changed out the USB cable as well. I feel like its something to do with the XBee its self.
rareed13
Re: XBee Progrmer Com loss
by rareed13 on Sun Feb 07, 2016 8:03 pm
More info. I have discovered, after more testing, that it will allow me to move both to a coordinator AT without programmer connection loss. Once I move to endpoint or router AT I start having connection issues. I'm starting to think this could be a firmware issue any advice on what to test next?
rareed13
cron
