Hello support,
Can a Adafruit ProTrinket (PRODUCT ID: 2000) natively attach to an xbee adapter (PRODUCT ID: 126) with the FTDI header?
I am trying to figure out if i can use the two in some sort of native fashion almost like a shield but instead of stacking on top connecting to the end via the FTDI header but without wires and only using pins.
Thanks for the help.
Can a Protrinket attach to xbee adapter natively?
- KevinB940
- Franklin97355
Re: Can a Protrinket attach to xbee adapter natively?
You don't need an FTDI cable to connect just connect RX on the ProTrinket to TX on the adapter and vice versa.
- KevinB940
But i would also need to power the xbee adapter so id also need power and ground.
What i was attempting to do was find a smaller arduino than a nano and make something like a xbee shield that could be plugged in with pin headers instead of wires for stability.
- Franklin97355
The Nano and Pro Trinket are both Uno processors and can be used the same. Both will work with the xbee adapter.But i would also need to power the xbee adapter so id also need power and ground.
