I know it's a issue of getting RTClib to work properly, but I'm stumped on what I'm doing wrong.
Example display code http://www.robotpirate.com/forums/index.php?topic=5.0
Example RTC code https://github.com/adafruit/RTClib/blob ... cf8523.ino
And the code that I attempted to splice the two together with:
// Arduinix 6 Bulb ( IN-17 )
// - Also supports Hour and Min. time set.
// This code runs a six bulb setup and displays a prototype clock setup.
// NOTE: the delay is setup for IN-17 nixie bulbs.
// by Jeremy Howa
// www.robotpirate.com
// www.arduinix.com
// 2008 - 2009
// Last Edit Aug 29, 2009
// SN74141 : True Table
//D C B A #
//L,L,L,L 0
//L,L,L,H 1
//L,L,H,L 2
//L,L,H,H 3
//L,H,L,L 4
//L,H,L,H 5
//L,H,H,L 6
//L,H,H,H 7
//H,L,L,L 8
//H,L,L,H 9
#define DEBUG_ON false
// SN74141 (1)
int ledPin_0_a = 2;
int ledPin_0_b = 3;
int ledPin_0_c = 4;
int ledPin_0_d = 5;
// SN74141 (2)
int ledPin_1_a = 6;
int ledPin_1_b = 7;
int ledPin_1_c = 8;
int ledPin_1_d = 9;
// anod pins
int ledPin_a_1 = 10;
int ledPin_a_2 = 11;
int ledPin_a_3 = 12;
#include <Wire.h>
#include "RTClib.h"
RTC_PCF8523 rtc;
void setup()
pinMode(ledPin_0_a, OUTPUT);
pinMode(ledPin_0_b, OUTPUT);
pinMode(ledPin_0_c, OUTPUT);
pinMode(ledPin_0_d, OUTPUT);
pinMode(ledPin_1_a, OUTPUT);
pinMode(ledPin_1_b, OUTPUT);
pinMode(ledPin_1_c, OUTPUT);
pinMode(ledPin_1_d, OUTPUT);
pinMode(ledPin_a_1, OUTPUT);
pinMode(ledPin_a_2, OUTPUT);
pinMode(ledPin_a_3, OUTPUT);
// NOTE:
// Grounding on pints 14 and 15 will set the Hour and Mins.
pinMode( 14, INPUT ); // set the vertual pin 14 (pin 0 on the analog inputs )
digitalWrite(14, HIGH); // set pin 14 as a pull up resistor.
pinMode( 15, INPUT ); // set the vertual pin 15 (pin 1 on the analog inputs )
digitalWrite(15, HIGH); // set pin 15 as a pull up resistor.
if( DEBUG_ON )
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
// DisplayNumberSet
// Use: Passing anod number, and number for bulb 1 and bulb 2, this function
// looks up the truth table and opens the correct outs from the arduino
// to light the numbers given to this funciton (num1,num2).
// On a 6 nixie bulb setup.
void DisplayNumberSet( int anod, int num1, int num2 )
int anodPin;
int a,b,c,d;
// set defaults.
a=0;b=0;c=0;d=0; // will display a zero.
anodPin = ledPin_a_1; // default on first anod.
// Select what anod to fire.
switch( anod )
case 0: anodPin = ledPin_a_1; break;
case 1: anodPin = ledPin_a_2; break;
case 2: anodPin = ledPin_a_3; break;
// Load the a,b,c,d.. to send to the SN74141 IC (1)
switch( num1 )
case 0: a=0;b=0;c=0;d=0;break;
case 1: a=1;b=0;c=0;d=0;break;
case 2: a=0;b=1;c=0;d=0;break;
case 3: a=1;b=1;c=0;d=0;break;
case 4: a=0;b=0;c=1;d=0;break;
case 5: a=1;b=0;c=1;d=0;break;
case 6: a=0;b=1;c=1;d=0;break;
case 7: a=1;b=1;c=1;d=0;break;
case 8: a=0;b=0;c=0;d=1;break;
case 9: a=1;b=0;c=0;d=1;break;
// Write to output pins.
digitalWrite(ledPin_0_d, d);
digitalWrite(ledPin_0_c, c);
digitalWrite(ledPin_0_b, b);
digitalWrite(ledPin_0_a, a);
// Load the a,b,c,d.. to send to the SN74141 IC (2)
switch( num2 )
digitalWrite(ledPin_1_d, d);
digitalWrite(ledPin_1_c, c);
digitalWrite(ledPin_1_b, b);
digitalWrite(ledPin_1_a, a);
// Turn on this anod.
digitalWrite(anodPin, HIGH);
// Delay
// NOTE: With the differnce in Nixie bulbs you may have to change
// this delay to set the update speed of the bulbs. If you
// dont wait long enough the bulb will be dim or not light at all
// you want to set this delay just right so that you have
// nice bright output yet quick enough so that you can multiplex with
// more bulbs.
delay(2);
// Shut off this anod.
digitalWrite(anodPin, LOW);
// DisplayNumberString
// Use: passing an array that is 8 elements long will display numbers
// on a 6 nixie bulb setup.
void DisplayNumberString( int* array )
// bank 1 (bulb 0,3)
DisplayNumberSet(0,array[0],array[3]);
// bank 2 (bulb 1,4)
DisplayNumberSet(1,array[1],array[4]);
// bank 3 (bulb 2,5)
DisplayNumberSet(2,array[2],array[5]);
// Defines
long MINS = 60; // 60 Seconds in a Min.
long HOURS = 60 * MINS; // 60 Mins in an hour.
long DAYS = 24 * HOURS; // 24 Hours in a day. > Note: change the 24 to a 12 for non millitary time.
long runTime = 0; // Time from when we started.
// default time sets. clock will start at 12:59:00
// NOTE: We start seconds at 0 so we dont need a clock set
// The values you see here would be what you change
// if you added a set clock inputs to the board.
//int clockHourSet = 12;
//int clockMinSet = 59;
int HourButtonPressed = false;
int MinButtonPressed = false;
void loop()
DateTime now = rtc.now();
int rtcYear;
int rtcMonth;
int rtcDay;
int rtcHour = (int)now.hour();
int rtcMinute = (int)now.minute();
int rtcSecond = (int)now.second();
// Get milliseconds.
// runTime = millis();
// Get time in seconds.
// long time = (runTime) / 1000;
int hourInput = digitalRead(14);
int minInput = digitalRead(15);
if( DEBUG_ON )
Serial.println( hourInput );
if( hourInput == 0 )
HourButtonPressed = true;
if( minInput == 0 )
MinButtonPressed = true;
// if( HourButtonPressed == true && hourInput == 1 )
// clockHourSet++;
// HourButtonPressed = false;
// if( MinButtonPressed == true && minInput == 1 )
// clockMinSet++;
// MinButtonPressed = false;
// Set time based on offset..
// long hbump = 60*60*rtcHour;
// long mbump = 60*rtcMinute;
// time += mbump + hbump;
// Convert time to days,hours,mins,seconds
// long days = time / DAYS; time -= days * DAYS;
// long hours = time / HOURS; time -= hours * HOURS;
// long minutes = time / MINS; time -= minutes * MINS;
// long seconds = time;
// Get the high and low order values for hours,min,seconds.
int lowerHours = rtcHour % 10;
int upperHours = rtcHour - lowerHours;
int lowerMins = rtcMinute % 10;
int upperMins = rtcMinute - lowerMins;
int lowerSeconds = rtcSecond % 10;
int upperSeconds = rtcSecond - lowerSeconds;
if( upperSeconds >= 10 ) upperSeconds = upperSeconds / 10;
if( upperMins >= 10 ) upperMins = upperMins / 10;
if( upperHours >= 10 ) upperHours = upperHours / 10;
// Fill in the Number array used to display on the tubes.
int NumberArray[6]={0,0,0,0,0,0};
NumberArray[0] = upperHours;
NumberArray[1] = lowerHours;
NumberArray[2] = upperMins;
NumberArray[3] = lowerMins;
NumberArray[4] = upperSeconds;
NumberArray[5] = lowerSeconds;
// Display.
DisplayNumberString( NumberArray );
EDIT:
It seems I was missing a rtc.begin() in the setup, and it works now!
EDIT EDIT:
Scratch that, it pulls from the compile time now, but doesn't change to the current time when it loses power. So close.
TRIPLE EDIT:
Actually really works now, just a issue with a leftover automatic time set line left in.
