Snap a picture of your ADAFRUIT clock and post it here!
Re: Snap a picture of your ADAFRUIT clock and post it here!
by N6BM on Mon Nov 21, 2016 2:21 pm
The photos show the Adafruit GPS clock complete with the Arduino UNO board, the Ultimate GPS board, the Adafruit relay board and 7 segment display. The code will close the N/O relay for (2) seconds at the top of each hour. The project was made for the time synchronizing circuit of a 1800's Western Union wall clock with GPS accuracy.
I didn't want to cut a hole into the front panel for the display, so I opted to use a strip of Velcro to keep the display in place. I was able to get help from Rick at Adafruit to incorporate the relay code into the GPS clock.
Completed GPS clock
Ultimate GPS + Arduino UNO + Adafruit N/O relay board + 7 segment (blue) display
N6BM
by erichs on Thu Nov 24, 2016 2:41 am
The photo shows a sand clock drawing the time into sand and erases it with vibration motors:
It features Adafruit PWM/Servo Driver (https://www.adafruit.com/product/815) and 500 mA Power Boost LiPo charger (https://www.adafruit.com/product/1944)
Videos and build instructions and project is described on https://mcuoneclipse.com/2016/11/23/mak ... and-clock/
Enjoy!
Erich
erichs
by adafruit_support_bill on Thu Nov 24, 2016 7:55 am
Awesome clock! Thanks for posting.
by liljester on Fri Feb 10, 2017 12:42 am
My newest clock built from Icetube parts.
liljester
by steveevy on Tue Mar 07, 2017 6:16 pm
Clock and thermometer display using node.js.
2017-03-07 08.51.19 800x800.png (949.31 KiB) Viewed 2643 times
Here is my "clock" although its primary purpose is a weather station to read the indoor and outdoor temperature with two DS18B20 digital thermometers. I'm using node.js, sqlite3 and guplot to display lots of data.
steveevy
by gadget_fan on Sun Mar 12, 2017 6:03 pm
I THINK that I am done with both building and modifying my ice-tube clock. It only took me 5 years! Stock clock hardware with a new ATMEG328 programmed with xmas-icetube firmware, an Ultimate GPS and the dimmer mod. I mounted the GPS under the unit and I think it is pretty unobtrusive there and seems to work just fine. I put a small piece of electrical tape over the GPS LED because I have the clock in my bedroom right now and the occasional red blink in the dark was annoying.
gadget_fan
by philross on Wed May 24, 2017 8:57 am
Digital Clock
Using 1.2 display, chronodot rtc, and 5 sensor capacitive touch breakout board.
philross
by mikeymaker on Wed Jun 28, 2017 11:16 pm
I'm inspired by all the great ideas here! First post on the forum and here's my clock from concept to reality.
Fritzing breadboard (actually documented last):
Prototype:
Stuffed into the case I designed:
Power ports:
...and a face:
Thanks for looking!
mikeymaker
by wacker on Tue Aug 01, 2017 2:53 am
This was mainly an exercise, to see if an arduino uno would run a parallel 8-bit 240x320 LCD and the spi port without clashes.
It is fine, using the excellent Adafruit libraries to drive the lcd, and the RTC DS3234 on the spi pins, and an added font.
Strangely hypnotic watching the seconds tick over ! Thanks guys.
wacker
by chris101 on Fri Nov 24, 2017 11:19 pm
Stopwatch with hundredth second precision, using a 3V trinket pro, battery charger backpack, 128 x 64 oled, chronodot, assorted switches, resistors capacitors and a 10K pot. The lens gives it a bit of Jules Verne appeal.
chris101
by chris101 on Sat Nov 25, 2017 12:34 am
This master "atomic" clock only has a few Adafruit parts, but they are essential (the chronodot and 128x32 oled), an Arduino Micro, the guts to a wwvb radio clock, some high brightness colored LEDs, a quad opamp, a bunch of vintage resistors, capacitors and other hardware. The hours, minutes and seconds are sent via a littleBits wireless device to several slave clocks.
chris101
by Stevence on Wed Sep 12, 2018 10:43 am
Just came across this thread. That's an amazingly-built digital clock, wacker!
Stevence
