Bash Error Adding a Real Time Clock to Raspberry Pi
by mengjialyu on Tue Aug 25, 2020 5:18 pm
Dear Community,
I have run into a problem following the tutorial https://learn.adafruit.com/adding-a-rea ... 2026484-18.
After inputting echo pcf8523 0x68 > /sys/class/i2c-adapter/i2c-1/new_device, I bumped into the error
bash: echo: write error: Device or resource busy
I have googled around and found no luck in resolving the issue. Could anyone provide some insights?
Thanks,
Mengjia
mengjialyu
Re: Bash Error Adding a Real Time Clock to Raspberry Pi
by adafruit_support_carter on Tue Aug 25, 2020 6:02 pm
Those steps are in the section:
Raspbian Wheezy or other pre-systemd Linux
Don't run those commands. Those would be very old OS versions at this point. So you only need to focus on the steps outlined in the section above:
Raspbian Jessie (Systemd)
by mengjialyu on Wed Aug 26, 2020 10:19 am
Dear Adafruit,
Thank you for your suggestions. It is now working fine : )
However, the time that's shown after running
date
is in BST. Is there a way for the time to be recorded in EST?
Thank you,
Mengjia
mengjialyu
by adafruit_support_carter on Wed Aug 26, 2020 10:58 am
Try setting your location. You can do that via raspi-config.
by mengjialyu on Wed Aug 26, 2020 7:13 pm
Thank you so much! I really appreciate your help!
mengjialyu
