PCF8523 Error in dmesg
by Jizobizo on Fri Nov 20, 2020 12:22 pm
I am unable to use the RTC PFC8523. i am getting the following in the dmesg:
pi@raspberrypi:~ $ dmesg | grep rtc
[ 5.725960] rtc-pcf8523 1-0068: failed to set xtal load capacitance: -121
[ 5.726604] rtc-pcf8523: probe of 1-0068 failed with error -121
dmesg8523.txt
(31.75 KiB) Downloaded 7 times
bootconfig.txt
(2.65 KiB) Downloaded 1 time
Jizobizo
Re: PCF8523 Error in dmesg
by adafruit_support_carter on Fri Nov 20, 2020 1:42 pm
Please post a photo of your setup showing how everything is connected.
by Jizobizo on Mon Nov 23, 2020 1:04 am
Using 5 volt for VCC.
Jizobizo
by adafruit_support_carter on Mon Nov 23, 2020 1:24 pm
Try switching to 3V for VCC. The Pi is a 3V board.
https://learn.adafruit.com/adafruit-pcf ... -2933148-3
by Jizobizo on Mon Nov 23, 2020 2:46 pm
I get the same thing on 3 volt, but i will try again and see. Also, if this is only a 3 volt item then you need to change the description.
"Equipped with PCF8523 RTC - it can run from 3.3V or 5V power & logic!"
https://www.adafruit.com/product/3295
Jizobizo
by adafruit_support_carter on Mon Nov 23, 2020 2:55 pm
It's not 3V only. But you need to match power to your board's logic level. From link above.
This chip can be powered by 3-5VDC so there is now on-board regulator. To power the board, give it the same power as the logic level of your microcontroller - e.g. for a 5V micro like Arduino, use 5V
In your case, it's 3.3V.
by Jizobizo on Mon Nov 23, 2020 4:24 pm
adafruit_support_carter wrote:It's not 3V only. But you need to match power to your board's logic level. From link above.
Ahh gotcha. I have it on 3.3v pin and i am not showing ID #68 in my i2cdetect output:
pi@raspberrypi:~ $ sudo i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
I have confirmed the voltage on the rtc and it matches whats coming out of the pi. Could i have hosed it when connecting to 5v??
Jizobizo
by Jizobizo on Mon Nov 23, 2020 4:57 pm
This is what i get when i did a full restore, before and after adding the dtoverlay=i2c-rtc,pcf8523 to the config.txt. This is on both a rpi 3b+ and a 4 4gb:
pi@raspberrypi:~ $ sudo i2cdetect -y 0
Error: Could not open file `/dev/i2c-0' or `/dev/i2c/0': No such file or directory
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.4.72-v7l+ (dom@buildbot) (gcc version 9.3.0 (Ubuntu 9.3.0-17ubuntu1~20.04)) #1356 SMP Thu Oct 22 13:57:51 BST 2020
[ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] On node 0 totalpages: 1012736
[ 0.000000] DMA zone: 2304 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 196608 pages, LIFO batch:63
[ 0.000000] HighMem zone: 816128 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s49804 r8192 d23924 u81920
[ 0.000000] pcpu-alloc: s49804 r8192 d23924 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1010432
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 smsc95xx.macaddr=DC:A6:32:73:60:02 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty3 consoleblank=0 loglevel=0 root=PARTUUID=38df017e-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x17cc0000-0x1bcc0000] (64MB)
[ 0.000000] Memory: 3655588K/4050944K available (10240K kernel code, 745K rwdata, 2836K rodata, 2048K init, 856K bss, 133212K reserved, 262144K cma-reserved, 3264512K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 31086 entries in 61 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] random: get_random_bytes called from start_kernel+0x338/0x520 with crng_init=0
[ 0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000023] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000102] bcm2835: system timer (irq = 17)
[ 0.000750] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000765] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000781] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000793] Switching to timer-based delay loop, resolution 18ns
[ 0.001028] Console: colour dummy device 80x30
[ 0.001061] printk: console [tty3] enabled
[ 0.001115] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[ 0.001136] pid_max: default: 32768 minimum: 301
[ 0.001285] LSM: Security Framework initializing
[ 0.001476] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001499] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002766] Disabling memory control group subsystem
[ 0.002887] CPU: Testing write buffer coherency: ok
[ 0.003397] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.004316] Setting up static identity map for 0x200000 - 0x20003c
[ 0.004524] rcu: Hierarchical SRCU implementation.
[ 0.005203] smp: Bringing up secondary CPUs ...
[ 0.006400] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.007728] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.008995] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.009152] smp: Brought up 1 node, 4 CPUs
[ 0.009168] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.009181] CPU: All CPU(s) started in HYP mode.
[ 0.009193] CPU: Virtualization extensions available.
[ 0.010015] devtmpfs: initialized
[ 0.023990] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.024250] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.024279] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.031028] pinctrl core: initialized pinctrl subsystem
[ 0.032014] NET: Registered protocol family 16
[ 0.036039] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.036639] audit: initializing netlink subsys (disabled)
[ 0.036891] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
[ 0.038139] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.038153] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.038482] Serial: AMBA PL011 UART driver
[ 0.042368] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.060828] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-10-22 13:59, variant start
[ 0.070843] raspberrypi-firmware soc:firmware: Firmware hash is 74e754ff8947c58d2773253f77f6f68a303188f8
[ 0.126467] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.131646] vgaarb: loaded
[ 0.132112] SCSI subsystem initialized
[ 0.132319] usbcore: registered new interface driver usbfs
[ 0.132391] usbcore: registered new interface driver hub
[ 0.132524] usbcore: registered new device driver usb
[ 0.132871] usb_phy_generic phy: phy supply vcc not found, using dummy regulator
[ 0.134814] clocksource: Switched to clocksource arch_sys_counter
[ 0.842284] VFS: Disk quotas dquot_6.6.0
[ 0.842383] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.842560] FS-Cache: Loaded
[ 0.842767] CacheFiles: Loaded
[ 0.843673] simple-framebuffer 3ea50000.framebuffer: framebuffer at 0x3ea50000, 0x177000 bytes, mapped to 0x(ptrval)
[ 0.843692] simple-framebuffer 3ea50000.framebuffer: format=a8r8g8b8, mode=800x480x32, linelength=3200
[ 0.844109] Console: switching to colour frame buffer device 100x30
[ 0.846102] simple-framebuffer 3ea50000.framebuffer: fb0: simplefb registered!
[ 0.856258] thermal_sys: Registered thermal governor 'step_wise'
[ 0.856620] NET: Registered protocol family 2
[ 0.857366] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.857397] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.857465] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.857532] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.857680] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.857712] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.857965] NET: Registered protocol family 1
[ 0.858723] RPC: Registered named UNIX socket transport module.
[ 0.858737] RPC: Registered udp transport module.
[ 0.858749] RPC: Registered tcp transport module.
[ 0.858762] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.858783] PCI: CLS 0 bytes, default 64
[ 0.860844] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.863049] Initialise system trusted keyrings
[ 0.863308] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 0.874161] FS-Cache: Netfs 'nfs' registered for caching
[ 0.874920] NFS: Registering the id_resolver key type
[ 0.874978] Key type id_resolver registered
[ 0.874991] Key type id_legacy registered
[ 0.875014] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.876149] Key type asymmetric registered
[ 0.876163] Asymmetric key parser 'x509' registered
[ 0.876356] bounce: pool size: 64 pages
[ 0.876416] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.876642] io scheduler mq-deadline registered
[ 0.876657] io scheduler kyber registered
[ 0.880799] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 0.880823] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 0.880895] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x0603ffffff -> 0x00f8000000
[ 0.880967] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x00bfffffff -> 0x0000000000
[ 0.936962] brcm-pcie fd500000.pcie: link up, 5 GT/s x1 (SSC)
[ 0.937286] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 0.937305] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.937325] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[ 0.937384] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 0.937655] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 0.940976] PCI: bus0: Fast back to back transfers disabled
[ 0.941208] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 0.941356] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.941789] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 0.945165] PCI: bus1: Fast back to back transfers disabled
[ 0.945225] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 0.945248] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 0.945330] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.945355] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 0.945673] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ 0.945917] pcieport 0000:00:00.0: PME: Signaling with IRQ 56
[ 0.946312] pcieport 0000:00:00.0: AER: enabled with IRQ 56
[ 0.946652] pci 0000:01:00.0: enabling device (0140 -> 0142)
[ 0.951773] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 0.954751] iproc-rng200 fe104000.rng: hwrng registered
[ 0.955154] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 0.955840] vc-sm: Videocore shared memory driver
[ 0.956430] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 0.968666] brd: module loaded
[ 0.981042] loop: module loaded
[ 0.982503] Loading iSCSI transport class v2.0-870.
[ 0.984512] libphy: Fixed MDIO Bus: probed
[ 0.985213] bcmgenet fd580000.ethernet: failed to get enet clock
[ 0.985232] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 0.985254] bcmgenet fd580000.ethernet: failed to get enet-wol clock
[ 0.985276] bcmgenet fd580000.ethernet: failed to get enet-eee clock
[ 0.985303] bcmgenet: Skipping UMAC reset
[ 1.004900] libphy: bcmgenet MII bus: probed
[ 1.094929] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.095965] usbcore: registered new interface driver r8152
[ 1.096043] usbcore: registered new interface driver lan78xx
[ 1.096101] usbcore: registered new interface driver smsc95xx
[ 1.096534] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.096579] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.099175] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[ 1.100465] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 1.100482] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.100499] usb usb1: Product: xHCI Host Controller
[ 1.100515] usb usb1: Manufacturer: Linux 5.4.72-v7l+ xhci-hcd
[ 1.100529] usb usb1: SerialNumber: 0000:01:00.0
[ 1.101165] hub 1-0:1.0: USB hub found
[ 1.101263] hub 1-0:1.0: 1 port detected
[ 1.101830] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.101857] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.101881] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.102413] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[ 1.102431] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.102447] usb usb2: Product: xHCI Host Controller
[ 1.102462] usb usb2: Manufacturer: Linux 5.4.72-v7l+ xhci-hcd
[ 1.102476] usb usb2: SerialNumber: 0000:01:00.0
[ 1.103067] hub 2-0:1.0: USB hub found
[ 1.103178] hub 2-0:1.0: 4 ports detected
[ 1.104702] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.105070] dwc_otg: FIQ enabled
[ 1.105083] dwc_otg: NAK holdoff enabled
[ 1.105096] dwc_otg: FIQ split-transaction FSM enabled
[ 1.105111] Module dwc_common_port init
[ 1.105545] usbcore: registered new interface driver uas
[ 1.105647] usbcore: registered new interface driver usb-storage
[ 1.105869] mousedev: PS/2 mouse device common for all mice
[ 1.107837] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.111370] sdhci: Secure Digital Host Controller Interface driver
[ 1.111382] sdhci: Copyright(c) Pierre Ossman
[ 1.112024] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 1.112660] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.116744] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.117054] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.117250] usbcore: registered new interface driver usbhid
[ 1.117263] usbhid: USB HID core driver
[ 1.118344] vchiq: vchiq_init_state: slot_zero = (ptrval)
[ 1.120294] [vc_sm_connected_init]: start
[ 1.129524] [vc_sm_connected_init]: end - returning 0
[ 1.131511] Initializing XFRM netlink socket
[ 1.131551] NET: Registered protocol family 17
[ 1.131656] Key type dns_resolver registered
[ 1.132175] Registering SWP/SWPB emulation handler
[ 1.132485] registered taskstats version 1
[ 1.132503] Loading compiled-in X.509 certificates
[ 1.133042] Key type ._fscrypt registered
[ 1.133056] Key type .fscrypt registered
[ 1.143699] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.143775] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 29, base_baud = 0) is a PL011 rev2
[ 1.143844] printk: console [ttyAMA0] enabled
[ 1.150012] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.151029] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.151045] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.201703] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.203359] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.206114] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.209120] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.210794] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.214855] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 1.217800] of_cfs_init
[ 1.218069] of_cfs_init: OK
[ 1.219649] Waiting for root device PARTUUID=38df017e-02...
[ 1.257053] random: fast init done
[ 1.283439] mmc1: new high speed SDIO card at address 0001
[ 1.323606] mmc0: new ultra high speed DDR50 SDHC card at address 59b4
[ 1.324528] mmcblk0: mmc0:59b4 SDU1 14.7 GiB
[ 1.326490] mmcblk0: p1 p2
[ 1.344368] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.344444] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.345871] devtmpfs: mounted
[ 1.354507] Freeing unused kernel memory: 2048K
[ 1.385122] Run /sbin/init as init process
[ 1.464914] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.647496] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.647515] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.647531] usb 1-1: Product: USB2.0 Hub
[ 1.649709] hub 1-1:1.0: USB hub found
[ 1.650027] hub 1-1:1.0: 4 ports detected
[ 1.866555] systemd[1]: System time before build time, advancing clock.
[ 1.968023] NET: Registered protocol family 10
[ 1.969367] Segment Routing with IPv6
[ 1.974923] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd
[ 1.998330] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 1.999118] systemd[1]: Detected architecture arm.
[ 2.066808] systemd[1]: Set hostname to <raspberrypi>.
[ 2.135149] usb 1-1.3: New USB device found, idVendor=0a12, idProduct=0001, bcdDevice=88.91
[ 2.135181] usb 1-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.135207] usb 1-1.3: Product: CSR8510 A10
[ 2.234893] usb 1-1.4: new full-speed USB device number 4 using xhci_hcd
[ 2.260737] uart-pl011 fe201000.serial: no DMA platform data
[ 2.381280] usb 1-1.4: New USB device found, idVendor=1b3f, idProduct=2008, bcdDevice= 1.00
[ 2.381300] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.381317] usb 1-1.4: Product: USB Audio Device
[ 2.381333] usb 1-1.4: Manufacturer: GeneralPlus
[ 2.390195] input: GeneralPlus USB Audio Device as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.3/0003:1B3F:2008.0001/input/input0
[ 2.455232] hid-generic 0003:1B3F:2008.0001: input,hidraw0: USB HID v2.01 Device [GeneralPlus USB Audio Device] on usb-0000:01:00.0-1.4/input3
[ 2.927994] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.939346] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.939742] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 2.940184] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.943289] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 2.943454] systemd[1]: Reached target Swap.
[ 2.944441] systemd[1]: Listening on Journal Audit Socket.
[ 2.945673] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.946459] systemd[1]: Listening on Syslog Socket.
[ 2.947684] systemd[1]: Created slice User and Session Slice.
[ 3.066974] i2c /dev entries driver
[ 3.597554] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.696036] systemd-journald[114]: Received request to flush runtime journal from PID 1
[ 4.359702] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.361694] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 4.361715] [vc_sm_connected_init]: start
[ 4.367987] [vc_sm_connected_init]: installed successfully
[ 4.385698] mc: Linux media interface: v0.10
[ 4.386278] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[ 4.386723] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[ 4.387534] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[ 4.387945] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[ 4.421981] videodev: Linux video capture interface: v2.00
[ 4.478117] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.480486] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.488749] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.509698] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.524085] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.542485] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 4.543097] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 4.543157] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 4.543482] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 4.544026] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 4.544441] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 4.544477] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 4.544504] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 4.544524] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 4.544544] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 4.544767] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 4.562968] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 4.563011] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 4.578574] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 4.578615] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 4.614233] input: raspberrypi-ts as /devices/platform/soc/soc:firmware/soc:firmware:touchscreen/input/input1
[ 4.892243] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 5.016719] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.051780] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 5.053122] checking generic (3ea50000 177000) vs hw (0 ffffffffffffffff)
[ 5.053139] fb0: switching to vc4drmfb from simple
[ 5.057352] Console: switching to colour dummy device 80x30
[ 5.057625] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 5.057638] [drm] No driver support for vblank timestamp query.
[ 5.057651] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
[ 5.059083] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 5.106271] Console: switching to colour frame buffer device 100x30
[ 5.120741] vc4-drm gpu: fb0: vc4drmfb frame buffer device
[ 5.120784] Bluetooth: Core ver 2.22
[ 5.120872] NET: Registered protocol family 31
[ 5.120886] Bluetooth: HCI device and connection manager initialized
[ 5.120911] Bluetooth: HCI socket layer initialized
[ 5.120932] Bluetooth: L2CAP socket layer initialized
[ 5.120964] Bluetooth: SCO socket layer initialized
[ 5.156029] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 5.163060] usbcore: registered new interface driver btusb
[ 5.235110] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 5.249604] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.250621] usbcore: registered new interface driver brcmfmac
[ 5.279839] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
[ 5.292065] usbcore: registered new interface driver snd-usb-audio
[ 5.520107] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.536753] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 23 2020 02:19:54 version 7.45.206 (r725000 CY) FWID 01-88ee44ea
[ 7.696933] random: crng init done
[ 7.696952] random: 7 urandom warning(s) missed due to ratelimiting
[ 8.000126] 8021q: 802.1Q VLAN Support v1.8
[ 8.384891] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 8.401981] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 8.401997] Bluetooth: BNEP filters: protocol multicast
[ 8.402027] Bluetooth: BNEP socket layer initialized
[ 8.548434] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 8.860944] Bluetooth: RFCOMM TTY layer initialized
[ 8.860974] Bluetooth: RFCOMM socket layer initialized
[ 8.861009] Bluetooth: RFCOMM ver 1.11
[ 9.066489] bcmgenet: Skipping UMAC reset
[ 9.068092] bcmgenet fd580000.ethernet: configuring instance for external RGMII
[ 9.068327] bcmgenet fd580000.ethernet eth0: Link is Down
[ 10.851189] broken atomic modeset userspace detected, disabling atomic
[ 13.969194] fuse: init (API version 7.31)
[ 14.234925] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 14.234951] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 20.453267] v3d fec00000.v3d: MMU error from client L2T (0) at 0x16c1000, pte invalid
pi@raspberrypi:~ $ dmesg | grep i2c
pi@raspberrypi:~ $ sudo nano /boot/config.txt
pi@raspberrypi:~ $ sudo reboot
login as: pi
pi@10.42.30.118's password:
Linux raspberrypi 5.4.72-v7l+ #1356 SMP Thu Oct 22 13:57:51 BST 2020 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Mon Nov 23 20:50:03 2020
SSH is enabled and the default password for the 'pi' user has not been changed.
This is a security risk - please login as the 'pi' user and type 'passwd' to set a new password.
pi@raspberrypi:~ $ dtoverlay=i2c-rtc,pcf8523
pi@raspberrypi:~ $
[ 5.665630] rtc-pcf8523 1-0068: failed to set xtal load capacitance: -121
[ 5.666320] rtc-pcf8523: probe of 1-0068 failed with error -121
[ 0.000006] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000022] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000099] bcm2835: system timer (irq = 17)
[ 0.000782] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000794] Switching to timer-based delay loop, resolution 18ns
[ 0.001030] Console: colour dummy device 80x30
[ 0.001064] printk: console [tty3] enabled
[ 0.001117] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[ 0.001138] pid_max: default: 32768 minimum: 301
[ 0.001478] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001502] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002764] Disabling memory control group subsystem
[ 0.003398] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.004314] Setting up static identity map for 0x200000 - 0x20003c
[ 0.004518] rcu: Hierarchical SRCU implementation.
[ 0.005194] smp: Bringing up secondary CPUs ...
[ 0.006385] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.007717] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.008985] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.009142] smp: Brought up 1 node, 4 CPUs
[ 0.009159] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.009172] CPU: All CPU(s) started in HYP mode.
[ 0.009184] CPU: Virtualization extensions available.
[ 0.010004] devtmpfs: initialized
[ 0.023987] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.024247] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.024276] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.030999] pinctrl core: initialized pinctrl subsystem
[ 0.031998] NET: Registered protocol family 16
[ 0.036049] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.036628] audit: initializing netlink subsys (disabled)
[ 0.036882] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
[ 0.038124] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.038138] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.038467] Serial: AMBA PL011 UART driver
[ 0.042394] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.060817] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-10-22 13:59, variant start
[ 0.070834] raspberrypi-firmware soc:firmware: Firmware hash is 74e754ff8947c58d2773253f77f6f68a303188f8
[ 0.126395] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.131566] vgaarb: loaded
[ 0.132030] SCSI subsystem initialized
[ 0.132234] usbcore: registered new interface driver usbfs
[ 0.132302] usbcore: registered new interface driver hub
[ 0.132423] usbcore: registered new device driver usb
[ 0.132772] usb_phy_generic phy: phy supply vcc not found, using dummy regulator
[ 0.134723] clocksource: Switched to clocksource arch_sys_counter
[ 0.841818] VFS: Disk quotas dquot_6.6.0
[ 0.841917] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.842097] FS-Cache: Loaded
[ 0.842293] CacheFiles: Loaded
[ 0.843189] simple-framebuffer 3ea50000.framebuffer: framebuffer at 0x3ea50000, 0x177000 bytes, mapped to 0x(ptrval)
[ 0.843210] simple-framebuffer 3ea50000.framebuffer: format=a8r8g8b8, mode=800x480x32, linelength=3200
[ 0.843630] Console: switching to colour frame buffer device 100x30
[ 0.845619] simple-framebuffer 3ea50000.framebuffer: fb0: simplefb registered!
[ 0.855715] thermal_sys: Registered thermal governor 'step_wise'
[ 0.856087] NET: Registered protocol family 2
[ 0.856832] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.856863] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.856932] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.857000] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.857150] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.857182] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.857445] NET: Registered protocol family 1
[ 0.858175] RPC: Registered named UNIX socket transport module.
[ 0.858189] RPC: Registered udp transport module.
[ 0.858201] RPC: Registered tcp transport module.
[ 0.858214] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.858235] PCI: CLS 0 bytes, default 64
[ 0.860294] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.862496] Initialise system trusted keyrings
[ 0.862784] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 0.873631] FS-Cache: Netfs 'nfs' registered for caching
[ 0.874378] NFS: Registering the id_resolver key type
[ 0.874426] Key type id_resolver registered
[ 0.874439] Key type id_legacy registered
[ 0.874463] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.875638] Key type asymmetric registered
[ 0.875652] Asymmetric key parser 'x509' registered
[ 0.875844] bounce: pool size: 64 pages
[ 0.875918] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.876147] io scheduler mq-deadline registered
[ 0.876162] io scheduler kyber registered
[ 0.880300] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 0.880323] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 0.880395] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x0603ffffff -> 0x00f8000000
[ 0.880467] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x00bfffffff -> 0x0000000000
[ 0.936845] brcm-pcie fd500000.pcie: link up, 5 GT/s x1 (SSC)
[ 0.937154] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 0.937173] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.937193] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[ 0.937252] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 0.937523] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 0.940877] PCI: bus0: Fast back to back transfers disabled
[ 0.941108] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 0.941255] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.941688] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 0.945089] PCI: bus1: Fast back to back transfers disabled
[ 0.945149] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 0.945172] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 0.945254] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.945279] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 0.945613] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ 0.945846] pcieport 0000:00:00.0: PME: Signaling with IRQ 56
[ 0.946244] pcieport 0000:00:00.0: AER: enabled with IRQ 56
[ 0.946583] pci 0000:01:00.0: enabling device (0140 -> 0142)
[ 0.951678] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 0.954663] iproc-rng200 fe104000.rng: hwrng registered
[ 0.955066] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 0.955756] vc-sm: Videocore shared memory driver
[ 0.956345] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 0.968555] brd: module loaded
[ 0.980907] loop: module loaded
[ 0.982385] Loading iSCSI transport class v2.0-870.
[ 0.984365] libphy: Fixed MDIO Bus: probed
[ 0.985066] bcmgenet fd580000.ethernet: failed to get enet clock
[ 0.985086] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 0.985109] bcmgenet fd580000.ethernet: failed to get enet-wol clock
[ 0.985131] bcmgenet fd580000.ethernet: failed to get enet-eee clock
[ 0.985159] bcmgenet: Skipping UMAC reset
[ 1.004814] libphy: bcmgenet MII bus: probed
[ 1.094835] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.095871] usbcore: registered new interface driver r8152
[ 1.095934] usbcore: registered new interface driver lan78xx
[ 1.095991] usbcore: registered new interface driver smsc95xx
[ 1.096422] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.096469] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.099082] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[ 1.100386] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 1.100405] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.100421] usb usb1: Product: xHCI Host Controller
[ 1.100436] usb usb1: Manufacturer: Linux 5.4.72-v7l+ xhci-hcd
[ 1.100451] usb usb1: SerialNumber: 0000:01:00.0
[ 1.101069] hub 1-0:1.0: USB hub found
[ 1.101166] hub 1-0:1.0: 1 port detected
[ 1.101731] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.101757] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.101781] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.102313] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[ 1.102331] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.102346] usb usb2: Product: xHCI Host Controller
[ 1.102362] usb usb2: Manufacturer: Linux 5.4.72-v7l+ xhci-hcd
[ 1.102377] usb usb2: SerialNumber: 0000:01:00.0
[ 1.102970] hub 2-0:1.0: USB hub found
[ 1.103057] hub 2-0:1.0: 4 ports detected
[ 1.104580] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.104950] dwc_otg: FIQ enabled
[ 1.104963] dwc_otg: NAK holdoff enabled
[ 1.104975] dwc_otg: FIQ split-transaction FSM enabled
[ 1.104991] Module dwc_common_port init
[ 1.105430] usbcore: registered new interface driver uas
[ 1.105546] usbcore: registered new interface driver usb-storage
[ 1.105739] mousedev: PS/2 mouse device common for all mice
[ 1.107689] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.111239] sdhci: Secure Digital Host Controller Interface driver
[ 1.111252] sdhci: Copyright(c) Pierre Ossman
[ 1.111891] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 1.112507] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.116414] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.116725] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.116925] usbcore: registered new interface driver usbhid
[ 1.116938] usbhid: USB HID core driver
[ 1.118022] vchiq: vchiq_init_state: slot_zero = (ptrval)
[ 1.119969] [vc_sm_connected_init]: start
[ 1.129190] [vc_sm_connected_init]: end - returning 0
[ 1.131151] Initializing XFRM netlink socket
[ 1.131193] NET: Registered protocol family 17
[ 1.131297] Key type dns_resolver registered
[ 1.131817] Registering SWP/SWPB emulation handler
[ 1.132127] registered taskstats version 1
[ 1.132146] Loading compiled-in X.509 certificates
[ 1.132710] Key type ._fscrypt registered
[ 1.132724] Key type .fscrypt registered
[ 1.143344] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.143419] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 29, base_baud = 0) is a PL011 rev2
[ 1.143486] printk: console [ttyAMA0] enabled
[ 1.149648] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.150662] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.150678] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.202035] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.203693] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.206372] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.209371] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.211040] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.218751] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 1.221930] of_cfs_init
[ 1.222075] of_cfs_init: OK
[ 1.223656] Waiting for root device PARTUUID=38df017e-02...
[ 1.260982] random: fast init done
[ 1.283365] mmc1: new high speed SDIO card at address 0001
[ 1.328356] mmc0: new ultra high speed DDR50 SDHC card at address 59b4
[ 1.329306] mmcblk0: mmc0:59b4 SDU1 14.7 GiB
[ 1.331136] mmcblk0: p1 p2
[ 1.343913] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.343987] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.345418] devtmpfs: mounted
[ 1.354177] Freeing unused kernel memory: 2048K
[ 1.385036] Run /sbin/init as init process
[ 1.464798] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.647383] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.647402] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.647419] usb 1-1: Product: USB2.0 Hub
[ 1.649302] hub 1-1:1.0: USB hub found
[ 1.649737] hub 1-1:1.0: 4 ports detected
[ 1.867259] systemd[1]: System time before build time, advancing clock.
[ 1.968775] NET: Registered protocol family 10
[ 1.970154] Segment Routing with IPv6
[ 1.974784] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd
[ 1.999397] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.000173] systemd[1]: Detected architecture arm.
[ 2.049222] systemd[1]: Set hostname to <raspberrypi>.
[ 2.134464] usb 1-1.3: New USB device found, idVendor=0a12, idProduct=0001, bcdDevice=88.91
[ 2.134488] usb 1-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.134504] usb 1-1.3: Product: CSR8510 A10
[ 2.234834] usb 1-1.4: new full-speed USB device number 4 using xhci_hcd
[ 2.241175] uart-pl011 fe201000.serial: no DMA platform data
[ 2.379730] usb 1-1.4: New USB device found, idVendor=1b3f, idProduct=2008, bcdDevice= 1.00
[ 2.379750] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.379768] usb 1-1.4: Product: USB Audio Device
[ 2.379784] usb 1-1.4: Manufacturer: GeneralPlus
[ 2.390592] input: GeneralPlus USB Audio Device as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.3/0003:1B3F:2008.0001/input/input0
[ 2.455213] hid-generic 0003:1B3F:2008.0001: input,hidraw0: USB HID v2.01 Device [GeneralPlus USB Audio Device] on usb-0000:01:00.0-1.4/input3
[ 2.912455] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.923899] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.924831] systemd[1]: Listening on Journal Socket.
[ 2.925261] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.925838] systemd[1]: Listening on Journal Socket (/dev/log).
[ 2.933507] systemd[1]: Mounting Kernel Debug File System...
[ 2.934517] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 2.936359] systemd[1]: Created slice User and Session Slice.
[ 2.942583] systemd[1]: Mounting POSIX Message Queue File System...
[ 2.943940] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 3.125934] i2c /dev entries driver
[ 3.562973] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.671849] systemd-journald[111]: Received request to flush runtime journal from PID 1
[ 4.318961] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[ 4.356576] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[ 4.357074] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[ 4.357861] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[ 4.397414] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.399910] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 4.399933] [vc_sm_connected_init]: start
[ 4.404131] [vc_sm_connected_init]: installed successfully
[ 4.421191] mc: Linux media interface: v0.10
[ 4.506916] input: raspberrypi-ts as /devices/platform/soc/soc:firmware/soc:firmware:touchscreen/input/input1
[ 4.545385] videodev: Linux video capture interface: v2.00
[ 4.628626] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.628949] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.642083] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.645917] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.651442] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.670425] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 4.670469] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 4.677608] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 4.678153] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 4.678589] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 4.678908] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 4.678935] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 4.678958] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 4.678979] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 4.679000] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 4.679188] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 4.689074] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 4.689120] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 4.698337] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 4.698380] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 4.747446] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.822925] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 4.833245] Bluetooth: Core ver 2.22
[ 4.833318] NET: Registered protocol family 31
[ 4.833332] Bluetooth: HCI device and connection manager initialized
[ 4.833357] Bluetooth: HCI socket layer initialized
[ 4.833378] Bluetooth: L2CAP socket layer initialized
[ 4.833412] Bluetooth: SCO socket layer initialized
[ 4.891704] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 4.896936] usbcore: registered new interface driver btusb
[ 4.944922] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 4.955401] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 4.955869] usbcore: registered new interface driver brcmfmac
[ 4.985620] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 4.985643] checking generic (3ea50000 177000) vs hw (0 ffffffffffffffff)
[ 4.985659] fb0: switching to vc4drmfb from simple
[ 4.988391] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
[ 5.004186] Console: switching to colour dummy device 80x30
[ 5.005403] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 5.005419] [drm] No driver support for vblank timestamp query.
[ 5.005432] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
[ 5.006627] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 5.028033] Console: switching to colour frame buffer device 100x30
[ 5.042261] vc4-drm gpu: fb0: vc4drmfb frame buffer device
[ 5.247476] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.251617] usbcore: registered new interface driver snd-usb-audio
[ 5.266444] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 23 2020 02:19:54 version 7.45.206 (r725000 CY) FWID 01-88ee44ea
[ 7.507763] random: crng init done
[ 7.507789] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.906765] 8021q: 802.1Q VLAN Support v1.8
[ 8.307141] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 8.335001] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 8.335016] Bluetooth: BNEP filters: protocol multicast
[ 8.335044] Bluetooth: BNEP socket layer initialized
[ 8.513749] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 8.747585] Bluetooth: RFCOMM TTY layer initialized
[ 8.747615] Bluetooth: RFCOMM socket layer initialized
[ 8.747650] Bluetooth: RFCOMM ver 1.11
[ 8.944817] bcmgenet: Skipping UMAC reset
[ 8.946536] bcmgenet fd580000.ethernet: configuring instance for external RGMII
[ 8.948213] bcmgenet fd580000.ethernet eth0: Link is Down
[ 10.800684] broken atomic modeset userspace detected, disabling atomic
[ 13.993566] fuse: init (API version 7.31)
[ 14.154930] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 14.154959] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 20.502701] v3d fec00000.v3d: MMU error from client L2T (0) at 0x1d21000, pte invalid
pi@raspberrypi:~ $
FullRestoreand3vout.txt
file of the above output.
(51.35 KiB) Not downloaded yet
Jizobizo
by adafruit_support_carter on Mon Nov 23, 2020 7:19 pm
Attaching to 5V would not have damaged the PCF. You risk damaging the Pi's pin though, since VCC sets the voltage level.
Do you have another I2C device and/or another Pi? (or even something like an Arduino board)
