Sorry for my bad English. ;)
I just take a flop with the following mounting, following the amendment of the Library for the display Adafruit "Adafruit 1.2" 4-Digit 7-Segment Display w / I2C Backpack. "The Python code is no longer suitable. and I am not able to change the Python code.
Link assembly with a Raspberry pi .:
https://learn.adafruit.com/large-pi-bas ... s?view=all
As I absolutely realize a montage that works, I found it with an Arduino UNO:
https://learn.adafruit.com/arduino-clock/hardware
But before ordering materials, I would like you to confirm that with this assembly I will not have problems with the Library or other Incompatibility ...
Thanks in advance.
Best regards,
Jacky
GPS CLOCK 7 SEGMENT LED DISPLAY: Notice ?
- adafruit_support_rick
Re: GPS CLOCK 7 SEGMENT LED DISPLAY: Notice ?
The Arduino project will work. There are no library issues.
- JackyNiew
Hello and thank you for your response.
Does the Python Code articles for Raspberry Pi, will eventually update to be compatible with the new librarys?
Best regards,
Jacky
Best regards,
Jacky
Are you using a Raspberry Pi 3? They changed the serial port on those, which broke a lot of programs that relied on the serial port.
- JackyNiew
No, it was a "Raspberry pi B" with Jessie.
And "1.2" 4-Digit 7-Segment Display w / I2C Backpack "and the new Library, I have error by following the assembly described here:
Someone told me that in the new Library was not compatible....
- adafruit2
we updated the entire library and tutorial a few days ago, plz start from scratch, it should work?
https://learn.adafruit.com/large-pi-bas ... -and-clock
- JackyNiew
Difficult to navigate ...
Indeed I see that the Libray date of 4 and 6 days, while my test date of 8 days ...
I will start my testing with this latest library ...
Thank you for having me informed.
Jacky
Jacky
- JackyNiew
YES! This works a lot with patches on the codes.
Your colleagues could have prevented me that a solution had been found to my problem.
My last post on the subject dated 28 October ... The day corrections were applied: viewtopic.php?f=8&t=55788&start=15
Thank you for these corrections indicated on the Library.
Best regards,
Jacky
Best regards,
Jacky
