I am new to the programing scene and I am having problem with my project. I wanted to start out easy but I can not get some things to work. I am trying to make a raspberry pi clock with a 7-segment led backpack from adafruit and so far it works as intended except one thing, the brightness of the display. the display I able to have 1-15 different brightness levels. I am trying to add the brightness code but I can't get it to work. I have used google and searched in the forums but can't seem to get the hang of it. Hope you guys could help out. At the moment it is on full brightness and is a bit annoying when trying to sleep next to it. :(
Here is the CODE:
#!/usr/bin/python
import time
import datetime
from Adafruit_LED_Backpack import SevenSegment
# Create display instance on default I2C address (0x70) and bus number.
display = SevenSegment.SevenSegment()
# Alternatively, create a display with a specific I2C address and/or bus.
# display = SevenSegment.SevenSegment(address=0x74, busnum=1)
# Initialize the display. Must be called once before using the display.
display.begin()
display.set_brightness(1)
# Keep track of the colon being turned on or off.
colon = False
# Clock Example
segment = SevenSegment.SevenSegment(address=0x70)
segment.begin()
print "Press CTRL+Z to exit"
# Continually update the time on a 4 char, 7-segment display
while(True):
now = datetime.datetime.now()
hour = now.hour
minute = now.minute
second = now.second
segment.clear()
# Set hours
segment.set_digit(0, int(hour / 10)) # Tens
segment.set_digit(1, hour % 10) # Ones
# Set minutes
segment.set_digit(2, int(minute / 10)) # Tens
segment.set_digit(3, minute % 10) # Ones
# Toggle colon
segment.set_colon(second % 2) # Toggle colon at 1Hz
# Write the display buffer to the hardware. This must be called to
# update the actual display LEDs.
segment.write_display()
# Wait a quarter second (less than 1 second to prevent colon blinking getting$
time.sleep(0.25)
