SI5351 output frequencies
Does the SI5351 allow you to set any frequency over the I2C bus? I need to be able to change frequencies and to be able to set frequencies over I2C from a microprocessor.
- adafruit_support_carter
Re: SI5351 output frequencies
It talks over I2C, but you should check your requirements for 'any' frequency against what it can actually do. Details in guide:
https://learn.adafruit.com/adafruit-si5 ... r-breakout
