Ice Tube Clock loosing time
Re: Ice Tube Clock loosing time
by fat16lib on Sat Sep 19, 2009 1:59 pm
Modern quartz watches have a calibration factor in prom that is set when they are manufactured. I think the factor is set by cutting traces with a laser on some watches.
The firmware for the Ice Tube Clock could be modified to have a calibration factor.
If the crystal load caps were a bit larger, the clock would start out loosing time. This loss could be adjusted when the hour rolls over by setting the register TCNT2 to a nonzero calibration factor here:
  // an hour...
  if (time_m >= 60) {
    TCNT2 = cal_factor; //Add this to adjust rate
    time_m = 0;
    time_h++;
This would cause the first second of each hour to be shorter by "cal_factor/256" of a second.
A menu to select cal_factor would be needed. One unit change in cal_factor would result in a rate change of about 0.1 second per day.
fat16lib
by ki4mmm on Sat Sep 19, 2009 7:21 pm
I've played with the crystal-caps on my clock a bit, and have gotten the loss from 4-sec/day to 2.5-sec/day, using 15pf caps (18pf dropped it to 3-sec/day). Because I like to tinker, and can't leave well enough alone, fat16lib's mention of a "calibration factor" sounds interesting to me.
Being new to AVR's and C (avr gcc), would the following be how one would try this (or maybe there is more to it than I think)?
1. Calculate the desired calibration factor e.g., (2.5-sec / 24) * 256 = 26.67
2. Declare the variable: float cal_factor = 26.67
3. Insert the above, and fat16lib's line into the code (then compile and download).
Also, maybe the precision of a decimal number is not needed (i.e., just getting the error under 1 sec would be nice), so maybe the calibration factor could just be an integer?
ki4mmm
by fat16lib on Sat Sep 19, 2009 8:02 pm
TCNT2 is uint8_t, an unsigned byte so use the closest integer.
fat16lib
by ki4mmm on Sat Sep 19, 2009 8:17 pm
Thank you!
ki4mmm
by eil on Sat Sep 19, 2009 8:20 pm
I've been wanting to play around with one of these:
http://search.digikey.com/scripts/DkSea ... 61-1014-ND
I read somewhere that somebody had some success connecting one to an arduino, so adding one to the Ice Tube clock kit shouldn't be impossible.
eil
by adafruit on Sun Sep 20, 2009 4:29 pm
