EEPROM write on the hour
by mike31416 on Wed Sep 16, 2009 6:08 pm
Looks like the EEPROM is updated each hour with the current hour and minutes. clock_init is called by main at startup and restores the time from EEPROM. The signal comparator function SIGNAL(SIG_COMPARATOR) stores the current minutes and seconds on power down.
Could the hour also be stored by SIGNAL(SIG_COMPARATOR) instead of being stored on the hour in the one second timer function SIGNAL (TIMER2_OVF_vect)?
It seems good to minimize the EEPROM writes. If you update it once and hour it will last for 11.5 years per the spec (100,000 updates). Seems like a long time and the display should be good for ten years so many be its not really an issue.
Heck I don't even know if I will be here 11 years from now ;)
Also looks like the wakeup function is not used.
Got to get a USBtinyISP soon so I can start hacking!!!
Mike
mike31416
Re: EEPROM write on the hour
by adafruit on Wed Sep 16, 2009 11:12 pm
yes we need to upload the latest firmware where we get rid of wakeup() it is an extraneous function
however we did the math on eeprom writes and decided that the -minimum- life was 10+ yrs and that we were happy with that.
