Ice Cube display suggestion
by Grant on Wed Sep 16, 2009 6:10 pm
I just received my kit and haven't built it yet, but after
reading through the docs, I've got a couple suggestions for the
display format:
1) Leading zero blanking. Displaying 9:00 as "9 00 00"
instead of "09 00 00" seems a bit more polished. [Perhaps
that's just a USian thing.]
2) Alarm indicator. Displaing negative values when the alarm
is on seems a bit strange. I'd probably use the rightmost
decimal point as an alarm-on indicator.
I'll probaby take a shot at changing the firmware.
Unfortunately I've got an Atmel JTAG interface but no ISP
interface. I'll have to see if I can find a cheap one...
Grant
Grant
Re: Ice Cube display suggestion
by mike31416 on Wed Sep 16, 2009 7:44 pm
How about the USBtinyISP ($22)? Or you can turn the Arduino into an AVR-ISP programmer:
http://tinker.it/now/2006/12/04/turn-ar ... rogrammer/
Mike
mike31416
by adafruit on Wed Sep 16, 2009 11:11 pm
we might get rid of the leading zero, it was sort of an arbitrary design decision. but the - was the only symbol we thought was legible from far away
by Grant on Thu Sep 17, 2009 10:53 am
mike31416 wrote:How about the USBtinyISP ($22)?
That's certainly looks like about as good a deal as you can
find. There are some slightly cheaper ones that use either
RS232 or parallel interfaces, but both of those are getting
rare. The cheaper ones also don't seem to be compatible with
avrdude.
Grant
by Grant on Thu Sep 17, 2009 11:09 am
adafruit wrote:we might get rid of the leading zero, it was sort of an
Certainly, and I think the leading zero is common in some regions.
away
That's true; I hadn't thought about that. I guess none of the
other alarm clocks I've used have alarm-on indicators that are
visible from more than a couple feet away, and that's never
bothered me.
I'll have to order the tinyUSB ISP kit and play with the
firmware.
Grant
by hinermad on Thu Sep 17, 2009 11:30 am
I've seen 12/24 hour clocks that displayed the leading zero if in 24 hour mode and blanked it in 12 hour mode.
The nice thing about an open-source clock is that you can do some neat things with it, like this:
http://xkcd.com/313/
hinermad
by sparr on Mon Sep 21, 2009 9:15 pm
If you want to buy a kit for me, I'd be happy to build an alternate firmware without the leading zero (or with an option), and with the alarm indicator moved to a decimal point.
sparr
