I just received my kit and haven't built it yet, but after
reading through the docs, I've got a couple suggestions for the
display format:
1) Leading zero blanking. Displaying 9:00 as "9 00 00"
instead of "09 00 00" seems a bit more polished. [Perhaps
that's just a USian thing.]
2) Alarm indicator. Displaing negative values when the alarm
is on seems a bit strange. I'd probably use the rightmost
decimal point as an alarm-on indicator.
I'll probaby take a shot at changing the firmware.
Unfortunately I've got an Atmel JTAG interface but no ISP
interface. I'll have to see if I can find a cheap one...
Grant
Ice Cube display suggestion
- mike31416
Re: Ice Cube display suggestion
How about the USBtinyISP ($22)? Or you can turn the Arduino into an AVR-ISP programmer:
http://tinker.it/now/2006/12/04/turn-ar ... rogrammer/
Mike
Mike
we might get rid of the leading zero, it was sort of an arbitrary design decision. but the - was the only symbol we thought was legible from far away
That's certainly looks like about as good a deal as you canmike31416 wrote:How about the USBtinyISP ($22)?
find. There are some slightly cheaper ones that use either
RS232 or parallel interfaces, but both of those are getting
rare. The cheaper ones also don't seem to be compatible with
avrdude.
Certainly, and I think the leading zero is common in some regions.adafruit wrote:we might get rid of the leading zero, it was sort of an
That's true; I hadn't thought about that. I guess none of thebut the - was the only symbol we thought was legible from far
away
other alarm clocks I've used have alarm-on indicators that are
visible from more than a couple feet away, and that's never
bothered me.
I'll have to order the tinyUSB ISP kit and play with the
firmware.
- hinermad
I've seen 12/24 hour clocks that displayed the leading zero if in 24 hour mode and blanked it in 12 hour mode.Grant wrote:Certainly, and I think the leading zero is common in some regions.adafruit wrote:we might get rid of the leading zero, it was sort of an
The nice thing about an open-source clock is that you can do some neat things with it, like this:
http://xkcd.com/313/
If you want to buy a kit for me, I'd be happy to build an alternate firmware without the leading zero (or with an option), and with the alarm indicator moved to a decimal point.
